Voice announcement for UK HO Tides (thanks @ianByrne)
Using @ianByrne UKHO tides HACS integration I made an automation of some custom sentences I thought I might quickly share. Feel free to add/correct.
Make sure to use your own tide sensor. Thanks @ianByrne
alias: tide sentences
description: "Some sentences to use with ianByrne HAC UKHO integration"
triggers:
  - trigger: conversation
    command:
      - When is [the] [next] low tide
    command:
      - When is [the] [next] high tide
    command:
      - Is the tide rising or falling
      - Is the tide falling or rising
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - when_low_tide
        sequence:
          - set_conversation_response: >
              {% set lt_in = state_attr('sensor.YOUR_TIDE_SENSOR',
              'next_low_tide_in').split(' ') %}
              {% set h = lt_in[0][:-1]|int %}
              {% set m = lt_in[1][:-1]|int %}
              The tide is currently {{states('sensor.YOUR_TIDE_SENSOR')}}.
              The next low tide is in {{h}} hour{{iif(h > 1, 's', '')}} and
              {{m}} minute{{iif(m > 1, 's', '')}}
              at {{ as_timestamp(state_attr('sensor.YOUR_TIDE_SENSOR',
              'next_low_tide_at'))|timestamp_custom ('%-H %M') }}.
              {% set low_height = state_attr('sensor.YOUR_TIDE_SENSOR',
              'next_low_tide_height') %}
              The predicted low is {{ low_height.split('m')[0] }} meters.
      - conditions:
            id:
              - when_high_tide
        sequence:
              {% set ht_in = state_attr('sensor.YOUR_TIDE_SENSOR',
              'next_high_tide_in').split(' ') %}
              {% set h = ht_in[0][:-1]|int %}
              {% set m = ht_in[1][:-1]|int %}
              The next high tide is in {{h}} hour{{iif(h > 1, 's', '')}} and
              'next_high_tide_at'))|timestamp_custom ('%-H %M') }}.
              {% set high_height = state_attr('sensor.YOUR_TIDE_SENSOR',
              'next_high_tide_height') %}
              The predicted high is {{ high_height.split('m')[0] }} meters.
      - conditions:
            id:
              - rising_or_falling
        sequence:
          - set_conversation_response: |
mode: single
