Voice Assistant answers only the second time
Overview
the first time I ask voice assistant a question the sound does not play. When I ask a second time shortly after, I do hear his answer. When I now wait a few minutes and ask something again, again the sound does not play.
My Setup
I have a conference microphone with speaker ( Anker PowerConf S330 ) connected directly to my RasPi 5 which runs Home Assistant OS.
I use:
  • Assist Microphone Addon (for local microphone)
  • Openwakeword with a custom wake word
  • ChatGPT as conversation agent
  • GroqCloud Whisper as SST, but also tested with Google AI STT
  • OpenAI TTS, but also tested with piper, google translate and Google AI TTS
My Observations
I think at some point this used to work. At the beginnings of the Voice Assistant. My whole setup.
I think it broke at sometime spring last year.
What happens:
The first time I ask a question after a while I hear no answer. In the debug logs I can see no errors. The agent did answer I just could not hear it. the chime at the start and end of my question does play, so I doubt it’s an audio issue.
When I ask shortly something again the sound does play correctly.
I tried all kinds of different setups but everything behaves the same.
I tried different SST, TTS and agents.
While the Debug Assistant does show the text-to-speech answer it may be worth noting that the β€œPlay Audio” button always returns β€œError playing audio”. But it does that in every case, even when I did hear the message being played.
Logs
Here is a log of the first question that plays NO SOUND:
Unsuccesful log
stage: done
run:
pipeline: 01kfdh20h4jbqf25cgb051jnfx
language: de
conversation_id: 01KHGKCGN4FNETWEAWJ740TGS9
satellite_id: assist_satellite.assist_microphone
tts_output:
token: TVW4A3tiBWHA8E3axq28EQ.wav
url: /api/tts_proxy/TVW4A3tiBWHA8E3axq28EQ.wav
mime_type: audio/x-wav
stream_response: true
events:
  • type: run-start
    language: de
    tts_output:
    timestamp: β€œ2026-02-15T12:11:11.911870+00:00”
  • type: wake_word-start
    entity_id: wake_word.openwakeword
    metadata:
    format: wav
    codec: pcm
    bit_rate: 16
    sample_rate: 16000
    channel: 1
    timeout: 0
    timestamp: β€œ2026-02-15T12:11:11.911986+00:00”
  • type: wake_word-end
    wake_word_output:
    wake_word_id: Mister_Chat_G_P_T_
    wake_word_phrase: Mister Chat G P T
    timestamp: 667780
    timestamp: β€œ2026-02-15T12:22:19.815337+00:00”
  • type: stt-start
    engine: stt.groqcloud_whisper
    metadata:
    language: de
    format: wav
    codec: pcm
    bit_rate: 16
    sample_rate: 16000
    channel: 1
    timestamp: β€œ2026-02-15T12:22:19.816498+00:00”
  • type: stt-vad-start
    timestamp: 668200
    timestamp: β€œ2026-02-15T12:22:20.882494+00:00”
  • type: stt-vad-end
    timestamp: 671020
    timestamp: β€œ2026-02-15T12:22:23.661177+00:00”
  • type: stt-end
    stt_output:
    text: " How is the weather today?"
    timestamp: β€œ2026-02-15T12:22:24.001334+00:00”
  • type: intent-start
    engine: conversation.chatgpt
    language: de
    intent_input: " How is the weather today?"
    device_id: cedf41be5cb823e8278b57a3973ad448
    prefer_local_intents: true
    timestamp: β€œ2026-02-15T12:22:24.001629+00:00”
  • type: intent-progress
    chat_log_delta:
    role: assistant
    timestamp: β€œ2026-02-15T12:22:26.734969+00:00”
    chat_log_delta:
    tool_calls:
    - tool_name: WeatherForecast
    tool_args: {}
    external: false
    timestamp: β€œ2026-02-15T12:22:27.168800+00:00”
    chat_log_delta:
    role: tool_result
    agent_id: conversation.chatgpt
    tool_call_id: call_vQ4HBZ01AqeM1UpBSftW4eYn
    tool_result:
    speech:
    plain:
    speech: |-
    The weather summary is: {
    β€œforecast”: [
                  {'condition': 'partlycloudy', 'precipitation_probability': 0.0, 'datetime': 'Sunday', 'wind_bearing': 152.0, 'uv_index': 1.6, 'temperature': -0.2, 'templow': -3.1, 'wind_gust_speed': 43.9, 'wind_speed': 23.8, 'precipitation': 0.0, 'humidity': 67}
                  {'condition': 'snowy', 'precipitation_probability': 87.1, 'datetime': 'Monday', 'wind_bearing': 131.0, 'uv_index': 1.5, 'temperature': -1.9, 'templow': -3.8, 'wind_gust_speed': 45.7, 'wind_speed': 24.8, 'precipitation': 2.5, 'humidity': 83}
                  {'condition': 'cloudy', 'precipitation_probability': 45.3, 'datetime': 'Tuesday', 'wind_bearing': 165.0, 'uv_index': 1.6, 'temperature': 2.3, 'templow': -1.8, 'wind_gust_speed': 19.4, 'wind_speed': 10.1, 'precipitation': 2.4, 'humidity': 97}
                  {'condition': 'cloudy', 'precipitation_probability': 17.6, 'datetime': 'Wednesday', 'wind_bearing': 333.4, 'temperature': -1.2, 'templow': -3.8, 'wind_speed': 12.2, 'precipitation': 0.0, 'humidity': 76}
                  {'condition': 'cloudy', 'precipitation_probability': 3.9, 'datetime': 'Thursday', 'wind_bearing': 66.7, 'temperature': -1.4, 'templow': -6.5, 'wind_speed': 7.9, 'precipitation': 0.0, 'humidity': 77}
                  {'condition': 'cloudy', 'precipitation_probability': 23.5, 'datetime': 'Friday', 'wind_bearing': 203.7, 'temperature': 1.6, 'templow': -7.9, 'wind_speed': 14.8, 'precipitation': 0.0, 'humidity': 70}
          extra_data: null
      response_type: action_done
        targets: []
        success: []
        failed: []
    created: "2026-02-15T12:22:27.187732+00:00"
    timestamp: β€œ2026-02-15T12:22:27.187877+00:00”
    chat_log_delta:
    role: assistant
    timestamp: β€œ2026-02-15T12:22:28.677860+00:00”
    chat_log_delta:
    content: Today’s
    timestamp: β€œ2026-02-15T12:22:28.678488+00:00”
    chat_log_delta:
    content: " weather"
    timestamp: β€œ2026-02-15T12:22:28.710638+00:00”
    chat_log_delta:
    content: " is"
    timestamp: β€œ2026-02-15T12:22:28.712253+00:00”
    chat_log_delta:
    content: " partly"
    timestamp: β€œ2026-02-15T12:22:28.776324+00:00”
    chat_log_delta:
    content: " cloudy"
    timestamp: β€œ2026-02-15T12:22:28.777179+00:00”
    chat_log_delta:
    content: " with"
    timestamp: β€œ2026-02-15T12:22:28.842759+00:00”
    chat_log_delta:
    content: " a"
    timestamp: β€œ2026-02-15T12:22:28.843882+00:00”
    chat_log_delta:
    content: " temperature"
    timestamp: β€œ2026-02-15T12:22:28.968605+00:00”
    chat_log_delta:
    content: " of"
    timestamp: β€œ2026-02-15T12:22:28.969435+00:00”
    chat_log_delta:
    content: " minus"
    timestamp: β€œ2026-02-15T12:22:29.036708+00:00”
    chat_log_delta:
    content: " point"
    timestamp: β€œ2026-02-15T12:22:29.037411+00:00”
    tts_start_streaming: true
    timestamp: β€œ2026-02-15T12:22:29.037444+00:00”
    chat_log_delta:
    content: " two"
    timestamp: β€œ2026-02-15T12:22:29.086249+00:00”
    chat_log_delta:
    content: " degrees"
    timestamp: β€œ2026-02-15T12:22:29.087316+00:00”
    chat_log_delta:
    content: " Celsius"
    timestamp: β€œ2026-02-15T12:22:29.110682+00:00”
    chat_log_delta:
    content: .
    timestamp: β€œ2026-02-15T12:22:29.111443+00:00”
    chat_log_delta:
    content: " The"
    timestamp: β€œ2026-02-15T12:22:29.139380+00:00”
    chat_log_delta:
    content: " humidity"
    timestamp: β€œ2026-02-15T12:22:29.140297+00:00”
    chat_log_delta:
    content: " is"
    timestamp: β€œ2026-02-15T12:22:29.191290+00:00”
    chat_log_delta:
    content: " at"
    timestamp: β€œ2026-02-15T12:22:29.192365+00:00”
    chat_log_delta:
    content: " sixty"
    timestamp: β€œ2026-02-15T12:22:29.232208+00:00”
    chat_log_delta:
    content: β€œ-seven”
    timestamp: β€œ2026-02-15T12:22:29.232846+00:00”
    chat_log_delta:
    content: " percent"
    timestamp: β€œ2026-02-15T12:22:29.247804+00:00”
    chat_log_delta:
    content: .
    timestamp: β€œ2026-02-15T12:22:29.251908+00:00”
  • type: intent-end
    processed_locally: false
    intent_output:
    response:
    speech:
    plain:
    speech: >-
    Today’s weather is partly cloudy with a temperature of minus
    point two degrees Celsius. The humidity is at sixty-seven
    percent.
    extra_data: null
    card: {}
    language: de
    targets:
    success:
    failed:
    continue_conversation: false
    timestamp: β€œ2026-02-15T12:22:29.287456+00:00”
  • type: tts-start
    engine: tts.openai_tts_onyx
    language: de
    voice: null
    tts_input: >-
    Today’s weather is partly cloudy with a temperature of minus point two
    degrees Celsius. The humidity is at sixty-seven percent.
    acknowledge_override: false
    timestamp: β€œ2026-02-15T12:22:29.287516+00:00”
  • type: tts-end
    tts_output:
    media_id: media-source://tts/-stream-/TVW4A3tiBWHA8E3axq28EQ.wav
    timestamp: β€œ2026-02-15T12:22:29.288244+00:00”
  • type: run-end
    data: null
    timestamp: β€œ2026-02-15T12:22:29.288288+00:00”
    started: 2026-02-15T12:11:11.911Z
    wake_word:
    metadata:
    format: wav
    codec: pcm
    bit_rate: 16
    sample_rate: 16000
    channel: 1
    timeout: 0
    done: true
    wake_word_output:
    timestamp: 667780
    stt:
    metadata:
    language: de
    format: wav
    codec: pcm
    bit_rate: 16
    sample_rate: 16000
    channel: 1
    done: true
    stt_output:
    intent:
    language: de
    done: true
    intent_output:
    response:
    speech:
    plain:
    speech: >-
    two degrees Celsius. The humidity is at sixty-seven percent.
    extra_data: null
    card: {}
    language: de
    targets:
    success:
    failed:
    tts:
    language: de
    voice: null
    tts_input: >-
    done: true
    tts_output:
    finished: 2026-02-15T12:22:29.288Z
And here is the log of the successful run shortly after
Successful
stage: done
run:
language: de
tts_output:
token: pxTx_MsZnvJWXN-prGwvzw.wav
url: /api/tts_proxy/pxTx_MsZnvJWXN-prGwvzw.wav
events:
  • type: run-start
    language: de
    tts_output:
    timestamp: β€œ2026-02-15T12:22:29.296949+00:00”
    metadata:
    format: wav
    codec: pcm
    bit_rate: 16
    sample_rate: 16000
    channel: 1
    timeout: 0
    timestamp: β€œ2026-02-15T12:22:29.297046+00:00”
    wake_word_output:
    timestamp: 12180
    timestamp: β€œ2026-02-15T12:22:41.451621+00:00”
  • type: stt-start
    metadata:
    language: de
    format: wav
    codec: pcm
    bit_rate: 16
    sample_rate: 16000
    channel: 1
    timestamp: β€œ2026-02-15T12:22:41.454288+00:00”
    timestamp: 12630
    timestamp: β€œ2026-02-15T12:22:42.514010+00:00”
  • type: stt-vad-end
    timestamp: 16140
    timestamp: β€œ2026-02-15T12:22:46.085965+00:00”
  • type: stt-end
    stt_output:
    text: " Kannst du deine letzte Antwort wiederholen?"
    timestamp: β€œ2026-02-15T12:22:46.437168+00:00”
    language: de
    intent_input: " Kannst du deine letzte Antwort wiederholen?"
    timestamp: β€œ2026-02-15T12:22:46.437465+00:00”
    chat_log_delta:
    role: assistant
    timestamp: β€œ2026-02-15T12:22:48.100600+00:00”
    chat_log_delta:
    content: Heute
    timestamp: β€œ2026-02-15T12:22:48.101833+00:00”
    chat_log_delta:
    content: " ist"
    timestamp: β€œ2026-02-15T12:22:48.120665+00:00”
    chat_log_delta:
    content: " das"
    timestamp: β€œ2026-02-15T12:22:48.121325+00:00”
    chat_log_delta:
    content: " Wetter"
    timestamp: β€œ2026-02-15T12:22:48.145384+00:00”
    chat_log_delta:
    content: " teilweise"
    timestamp: β€œ2026-02-15T12:22:48.146544+00:00”
    chat_log_delta:
    content: " bew"
    timestamp: β€œ2026-02-15T12:22:48.167360+00:00”
    chat_log_delta:
    content: ΓΆl
    timestamp: β€œ2026-02-15T12:22:48.168593+00:00”
    chat_log_delta:
    content: kt
    timestamp: β€œ2026-02-15T12:22:48.189818+00:00”
    chat_log_delta:
    content: " bei"
    timestamp: β€œ2026-02-15T12:22:48.191109+00:00”
    chat_log_delta:
    content: " einer"
    timestamp: β€œ2026-02-15T12:22:48.208808+00:00”
    chat_log_delta:
    content: " Temperatur"
    timestamp: β€œ2026-02-15T12:22:48.209825+00:00”
    chat_log_delta:
    content: " von"
    timestamp: β€œ2026-02-15T12:22:48.250298+00:00”
    timestamp: β€œ2026-02-15T12:22:48.250383+00:00”
    chat_log_delta:
    content: " minus"
    timestamp: β€œ2026-02-15T12:22:48.253626+00:00”
    chat_log_delta:
    content: " zwei"
    timestamp: β€œ2026-02-15T12:22:48.284712+00:00”
    chat_log_delta:
    content: " Grad"
    timestamp: β€œ2026-02-15T12:22:48.285754+00:00”
    chat_log_delta:
    content: " Celsius"
    timestamp: β€œ2026-02-15T12:22:48.311058+00:00”
    chat_log_delta:
    content: .
    timestamp: β€œ2026-02-15T12:22:48.312175+00:00”
    chat_log_delta:
    content: " Die"
    timestamp: β€œ2026-02-15T12:22:48.329729+00:00”
    chat_log_delta:
    content: " Luft"
    timestamp: β€œ2026-02-15T12:22:48.330993+00:00”
    chat_log_delta:
    content: fe
    timestamp: β€œ2026-02-15T12:22:48.353970+00:00”
    chat_log_delta:
    content: uchtigkeit
    timestamp: β€œ2026-02-15T12:22:48.355589+00:00”
    chat_log_delta:
    content: " betrΓ€gt"
    timestamp: β€œ2026-02-15T12:22:48.376080+00:00”
    chat_log_delta:
    content: " sechs"
    timestamp: β€œ2026-02-15T12:22:48.376853+00:00”
    chat_log_delta:
    content: und
    timestamp: β€œ2026-02-15T12:22:48.423794+00:00”
    chat_log_delta:
    content: se
    timestamp: β€œ2026-02-15T12:22:48.424879+00:00”
    chat_log_delta:
    content: ch
    timestamp: β€œ2026-02-15T12:22:48.448980+00:00”
    chat_log_delta:
    content: zig
    timestamp: β€œ2026-02-15T12:22:48.450444+00:00”
    chat_log_delta:
    content: " Prozent"
    timestamp: β€œ2026-02-15T12:22:48.459031+00:00”
    chat_log_delta:
    content: .
    timestamp: β€œ2026-02-15T12:22:48.462350+00:00”
  • type: intent-end
    intent_output:
    response:
    speech:
    plain:
    speech: >-
    Heute ist das Wetter teilweise bewΓΆlkt bei einer Temperatur von
    minus zwei Grad Celsius. Die Luftfeuchtigkeit betrΓ€gt
    sechsundsechzig Prozent.
    extra_data: null
    card: {}
    language: de
    targets:
    success:
    failed:
    timestamp: β€œ2026-02-15T12:22:48.502026+00:00”
  • type: tts-start
    language: de
    voice: null
    tts_input: >-
    Heute ist das Wetter teilweise bewΓΆlkt bei einer Temperatur von minus
    zwei Grad Celsius. Die Luftfeuchtigkeit betrΓ€gt sechsundsechzig Prozent.
    timestamp: β€œ2026-02-15T12:22:48.502082+00:00”
  • type: tts-end
    tts_output:
    media_id: media-source://tts/-stream-/pxTx_MsZnvJWXN-prGwvzw.wav
    timestamp: β€œ2026-02-15T12:22:48.503459+00:00”
  • type: run-end
    data: null
    timestamp: β€œ2026-02-15T12:22:48.503500+00:00”
    started: 2026-02-15T12:22:29.296Z
    wake_word:
    metadata:
    format: wav
    codec: pcm
    bit_rate: 16
    sample_rate: 16000
    channel: 1
    timeout: 0
    done: true
    wake_word_output:
    timestamp: 12180
    stt:
    metadata:
    language: de
    format: wav
    codec: pcm
    bit_rate: 16
    sample_rate: 16000
    channel: 1
    done: true
    stt_output:
    intent:
    language: de
    done: true
    intent_output:
    response:
    speech:
    plain:
    speech: >-
    extra_data: null
    card: {}
    language: de
    targets:
    success:
    failed:
    tts:
    language: de
    voice: null
    tts_input: >-
    Heute ist das Wetter teilweise bewΓΆlkt bei einer Temperatur von minus zwei
    done: true
    tts_output:
    finished: 2026-02-15T12:22:48.503Z
I couldn’t find anything else relevant in any other logs.
The addon app is based on a code that has been discontinued.
Don’t waste your time trying to figure this out; it’s better to switch to Linux-Voice-Assistant.
There’s no official addon yet, only a Docker container. But perhaps someone has already converted the container into an add-on format; check GitHub.
It worked! And it is so much better. Thanks for the advise.
I installed it via this addon if anyone cares.
