Hi there, i’ve set up a DIY smart speaker with a ESP32-S3 and a pair of audio ADC/DAC which are working quite well for listening to wakewords, playing responses and, recently, playing media after following this example.
Now I can play media such as local files or radio stations on this device as a media device, but while playing, it doesn’t listen to the wake word at all.
I couldn’t find any information about this situation here in the forum so I’m posting this as a new topic, but I’d really appreciate if someone could point me to an existing content in this subject.
Below is my yaml config for the esphome device.
esphome:
friendly_name: Voice Assistant S3
platformio_options:
board_build.flash_mode: dio
on_boot:
- light.turn_on:
blue: 100%
brightness: 60%
effect: fast pulse
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_AUDIO_BOARD_CUSTOM: "y"
psram:
mode: octal # quad for N8R2 and octal for N16R8
speed: 80MHz
# Enable logging
logger:
hardware_uart: UART0
# Enable Home Assistant API
api:
encryption:
key: !secret secret_key
on_client_connected:
then:
- delay: 50ms
- light.turn_off: led_ww
- micro_wake_word.start:
on_client_disconnected:
then:
- voice_assistant.stop:
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
captive_portal:
button:
- platform: restart
switch:
optimistic: true
on_turn_on:
- micro_wake_word.stop:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 60%
effect: fast pulse
- delay: 2s
- light.turn_off:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
brightness: 30%
on_turn_off:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
brightness: 60%
effect: fast pulse
- delay: 2s
- light.turn_off:
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: GPIO48
num_leds: 1
#rmt_channel: 0
chipset: ws2812
name: "on board light"
effects:
- pulse:
- pulse:
transition_length: 0.5s
update_interval: 0.5s
min_brightness: 0%
max_brightness: 100%
# Audio and Voice Assistant Config
i2s_audio:
- id: i2s_in
i2s_lrclk_pin: GPIO3 #WS
i2s_bclk_pin: GPIO2 #SCK
- id: i2s_speaker
i2s_lrclk_pin: GPIO6 #LRC
i2s_bclk_pin: GPIO7 #BLCK
microphone:
- platform: i2s_audio
adc_type: external
i2s_din_pin: GPIO4 #SD pin on the INMP441
channel: left
pdm: false
i2s_audio_id: i2s_in
bits_per_sample: 32 bit
speaker:
i2s_audio_id: i2s_speaker
dac_type: external
i2s_dout_pin: GPIO8 # DIN Pin of the MAX98357A Audio Amplifier
sample_rate: 16000
- platform: mixer
output_speaker: va_speaker
source_speakers:
- id: announcement_spk_mixer_input
- id: media_spk_mixer_input
- platform: resampler
output_speaker: media_spk_mixer_input
output_speaker: announcement_spk_mixer_input
media_player:
- platform: speaker
name: "Nabu Media Player"
media_pipeline:
speaker: media_spk_resampling_input
num_channels: 2
announcement_pipeline:
speaker: announcement_spk_resampling_input
num_channels: 1
micro_wake_word:
on_wake_word_detected:
# then:
- voice_assistant.start:
wake_word: !lambda return wake_word;
- light.turn_on:
red: 30%
green: 30%
blue: 70%
brightness: 60%
effect: fast pulse
models:
- model: okay_nabu
voice_assistant:
microphone: va_mic
noise_suppression_level: 2.0
volume_multiplier: 4.0
on_error:
on_end:
then:
- wait_until:
not:
voice_assistant.is_running:
