I updated to the latest Home Assistant (docker) and now I am getting my voice assistant reply in a loop. Not right after, but about a minute apart.
Example:
Q: What time is it.
A: The time is 7:00 pm.
one minute later: The time is 7:00 pm.
and so on…
I checked the tts directory and there is only one file it created. So it is playing the same mp3 file every minute.
Here is my ESPHome file:
esphome:
friendly_name: Voice Assist 003
on_boot:
- priority: -100
then:
- wait_until: api.connected
- delay: 1s
- if:
condition:
switch.is_on: use_wake_word
then:
- voice_assistant.start_continuous:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxx"
ota:
- platform: esphome
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: xxx.xxx.xxx.xxx
gateway: 192.169.1.1
subnet: 255.255.255.0
ap:
ssid: "xxxxxxxxxxxxxxxxxx"
password: "xxxxxxxxxxxxxx"
captive_portal:
i2s_audio:
- id: i2s_in
i2s_lrclk_pin: GPIO26 #WS
i2s_bclk_pin: GPIO25 #SCK
microphone:
- platform: i2s_audio
adc_type: external
pdm: false
channel: right
bits_per_sample: 32bit
i2s_audio_id: i2s_in
i2s_din_pin: GPIO33 #SD Pin from the INMP441 Microphone
media_player:
dac_type: external
i2s_dout_pin: GPIO27 # DIN Pin of the MAX98357A Audio Amplifier
mode: mono
voice_assistant:
microphone: mic_i2s
noise_suppression_level: 2
auto_gain: 31dBFS
volume_multiplier: 8.0
use_wake_word: false
media_player: media_player_speaker
on_wake_word_detected:
- light.turn_on:
on_listening:
- light.turn_on:
effect: "Rainbow Spinner"
# red: 71%
# green: 0%
# blue: 71%
on_stt_end:
- light.turn_on:
effect: "None"
red: 0%
green: 100%
blue: 0%
on_error:
- light.turn_on:
effect: "None"
red: 100%
green: 0%
blue: 0%
- if:
condition:
then:
- switch.turn_off: use_wake_word
- delay: 1sec
- switch.turn_on: use_wake_word
on_tts_start: # this is required to play the output on a media player
- homeassistant.service:
service: tts.speak
media_player_entity_id: media_player.voice_assist_003_esp_speaker #replace this with your media player entity id
message: !lambda 'return x;'
entity_id: tts.piper_3 #replace this with your piper tts id.
on_client_connected:
- if:
condition:
then:
on_client_disconnected:
- if:
condition:
then:
- voice_assistant.stop:
on_end:
- light.turn_off:
binary_sensor:
- platform: status
name: API Connection
filters:
- delayed_on: 1s
on_press:
- if:
condition:
then:
on_release:
- if:
condition:
then:
switch:
name: Use wake word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
entity_category: config
on_turn_on:
- lambda: id(va).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- lambda: id(va).set_use_wake_word(false);
- platform: restart
name: "Restart This Bitch"
light:
- platform: neopixelbus
type: grb
pin: GPIO32 # DIN pin of the LED Strip
num_leds: 24 # change the Number of LEDS according to your LED Strip.
variant: ws2812x
default_transition_length: 0.5s
effects:
- addressable_scan:
name: Scan Effect With Custom Values
move_interval: 50ms
scan_width: 2
- addressable_rainbow:
speed: 50
width: 24
speed: 50
- addressable_random_twinkle:
name: Random Twinkle Effect With Custom Values
twinkle_probability: 50%
progress_interval: 32ms
- addressable_flicker:
name: Flicker Effect With Custom Values
update_interval: 16ms
intensity: 100%
