Voice Assistant PE button trigger not showing in GUI
I’ve read the following threads:
  • Voice PE button press triggers Easter egg
  • Trigger an automation on an event with no state change (Voice Assistant PE button)
However, I still can’t figure out how to create an automation trigger for the Voice PE button single/double or triple press. I can see the button press in the “Scene” section, but I’m not sure what changes to make or where to make them. If I need to edit a YAML file, could someone point me in the right direction?
I’m still new to Home Assistant, so any guidance would be really helpful. Thank you!
Firmware: 25.2.1 (ESPHome 2025.2.0)
I’m not sure if this is the right approach. First, I do a double press so the button becomes available. Then, I add an automation and include a “state” condition, searching for the button. After that, I add “state” again. Because of the double press, I can see the event type.
