Is it possible to have voice assistant answer a question by playing a .wav file?
I assume I will have to create an automation that triggers when a specific question is said, then the action be play the wav file. I don’t know if it’s possible to play the wave file or if the “Set conversation response” action only takes text input
Thanks @mchk, I gave that a try and got an error. I think home assistant is not seeing my speaker as a media device. The entity type is assist_satellite which i guess is not a media device. If I use the drop down to select a media device in the actions section of the automation, it is not an option. My speaker is a raspberry pi 4, I don’t know if that makes a difference.
Are you using a wyoming satellite? Then you don’t have a media_player entity.
Try using assist_satellite.announce action.
If a more complete answer is required, please provide full details.
