Welcome to Voice Chapter 11 đ, our long-running series where we share all the key developments in Open Voice. In this chapter, we will tell you how our assistant can now control more things in the home, in multiple languages at the same time, all while not talking your ear off. Whatâs more, our list of supported languages has grown again with several languages that big techâs voice assistants wonât support. Join us for a deeper look at this voice chapter in our livestream on Wednesday, October 29. Itâs been a couple of months, weâve been building up our voice, and now have a lot to say, so letâs get to it!
Multilingual assistants
Our original goal for the Year of Voice back in 2023 was to âlet users control Home Assistant in their own languageâ. Weâve come a long way towards that goal, and really broadened our language support. Weâve also provided options that allow users to customize voice assistant pipelines with the services that best support their language, whether run locally or in the cloud of their choice. But what if you speak two languages within your home?
For some time, users have been able to create Assist voice assistant pipelines for different languages in Home Assistant, but interacting with the different pipelines has either required multiple voice satellite devices (one per language) or some kind of automation trigger to switch languages.
Since even the tiniest voice satellite hardware we support is capable of running multiple wake words now, weâve added support in 2025.10 for configuring up to two wake words and voice assistant pipelines on each Assist satellite! This makes it straightforward to support dual language households by assigning different wake words to different languages. For example, âOkay Nabuâ could run an English voice assistant pipeline while âHey Jarvisâ is used for French.
Multiple wake words and pipelines can be used for other purposes as well. Want to keep your local and cloud-based voice assistants separate? Easy! Assign a wake word like âOkay Nabuâ to a fully local pipeline using our own Speech-to-Phrase and Piper. This pipeline would be limited to basic voice commands, but would not require anything to run outside of your Home Assistant server. Alongside this, âHey Jarvisâ could be assigned to a different pipeline that uses external services like Home Assistant Cloud and an LLM to answer questions or perform complex actions.
Weâd love to hear feedback on how you plan to use multiple wake words and voice assistants in your home!
Voice without AI
The whole world is engulfed in hype about AI and adding it to all the things â weâre not exactly quiet about the cool stuff weâre doing with AI. While powering your voice assistants with AI/LLMs makes them much more flexible and powerful, it comes at a cost: paying to use cloud-based services like OpenAI and Google, or pricey hardware and energy to run local models via systems like Ollama. We started building our voice assistant before AI was a thing, and thus it was designed without requiring it. We continue to make great progress towards delivering a solid voice experience to users who want to keep their home AI free â keeping AI opt-in only and not required are guidelines we follow.
Assist, our built-in voice assistant, can do a lot of cool things without the need for AI! This includes a ton of voice commands in dozens of languages for:
- Turning lights and other devices on/off
- Opening/closing and locking/unlocking doors, windows, shades, etc
- Adjusting the brightness and color of lights
- Running scripts and activating scenes
- Controlling media players and adjusting their volume
- Playing music on supported media players via Music Assistant
- Starting/stopping/pausing multiple timers, optionally with names
- Adding/completing items on to-do lists
- Delaying a command for later (âturn off lights in 5 minutesâ)âŚ
- âŚand more!
Want to include your own voice commands? You can quickly add custom sentences to an automation, allowing you to take any action and tailor the response.
The easiest way to get started is with Home Assistant Voice Preview Edition, our small and easy-to-start with Voice Assistant hardware. This, combined with a Home Assistant Cloud subscription, allows any Home Assistant system to quickly handle voice commands, as our privacy-focused cloud processes the speech-to-text (turning your voice into text for Home Assistant) and text-to-speech (turning Home Assistantâs response back into voice). This is all without the use of LLMs, and supports the development of Home Assistant đ.
For users wanting to keep all voice processing local, we offer add-ons for both speech-to-text and text-to-speech:
All of this together shows just how much can be done without needing to include AI, even though it can do some pretty amazing things. And weâre continuing to close the gap with the features highlighted in this blog post, including multilingual assistants, improved sentence matching, and the ability to ask questions from automations.
More intents
Intents are what connect a voice command to the right actions in Home Assistant to get something done. While the end result is often simple, such as turning on a light, intents are designed as a âdo what I meanâ layer above the level of basic actions. In the previous section, we listed the sorts of voice commands that intents enable, from turning on lights to adding items to your to-do list. Over the last three years, weâve been progressively adding new and more complex intents.
Recently, weâve added three new intents to make Assist even better. To control media players, you can now set the relative volume with voice commands like âturn up the volumeâ or âdecrease TV volume by 25%â. This adds to the existing volume intent, which allows you to set the absolute volume level like âset TV volume to 50%â.
Next, itâs now possible to set the speed of a fan by percentage. For example, âset desk fan speed to 50%â or even âset fans to 50%â to target all fans in the current area. Make sure you expose the fans you want Assist to be able to control.
Lastly, you can now tell the kids to âget off your lawnâ because your robot is going to mow it! Making use of the lawn_mower integration, your voice assistant can now understand commands like âmow the lawnâ and âstop the mowerâ. Paired with the existing smart vacuum commands, you may never need to lift a finger again to keep things clean and tidy.
Ask question
Picture this: you come home from work and, as you enter the living room, your voice assistant asks what type of music youâd like to hear while preparing dinner. As the music starts to play, it mentions you left the garage door open and wants to know if youâd like it closed. After dinner, as youâre hanging out on the couch, your voice assistant informs you that the temperature outside is lower than your AC setting and asks for confirmation to turn it off and open the windows.
Surely youâd need a powerful LLM to perform such wizardry, right? With the Ask Question action, this can all be done locally using Assist and a few automations!
Within an automation, the Ask Question action allows you to announce a message on a voice satellite, match the response against a list of possible answers, and take an action depending on the userâs answer. While answers can be open-ended, such as a musical artist or genre, limiting the possible answers allows you to use the fully local Speech-to-Phrase for recognizing speech without an internet connection.
Improved sentence matching
Assist was designed to run fast and fully offline on hardware like the Raspberry Pi 4 for many different languages. It works by matching the text of your voice commands against sentence templates, such as âturn on the {name}â or âturn off lights in the {area}â. While this is very fast and straightforward to translate to many languages, it can also be inflexible, resulting in the dreaded âSorry, I couldnât understand thatâ or other errors.
Starting in Home Assistant 2025.9, weâve included an improved âfuzzy matcherâ that is much better at handling extra words or alternative phrasings of our supported voice commands.
The fuzzy matcher is pre-trained on the existing sentence templates, so we will be able to use it for all of our supported languages. However, this is initially only available for the English language and weâre working to determine the best way to enable this for other languages.
Non-verbal confirmations
After a voice command, Assist responds with a short confirmation like âTurned on the lightsâ or âBrightness setâ. This lets you know it understood your command and took the appropriate actions. However, if youâre in the same room as the voice assistant, this confirmation is redundant; you can see or hear that appropriate actions were taken.
Starting with Home Assistant 2025.10, Assist will detect if the voice commandâs actions all took place within the same area as the satellite device. If so, a short confirmation âbeepâ will be played instead of the full verbal response. Besides being less verbose, this also serves as a reminder that your voice command only affected the current area.
Non-verbal confirmations will not be used in voice assistant pipelines with LLMs, since the user may have specific instructions in their prompt, such as ârespond like a pirateâ, and we wouldnât want to deprive you of a fun response, me mateys đ´ââ ď¸.
Text-to-speech streaming
Large language models (LLMs) can be especially verbose in their responses, and we quickly realized that this exposed a weakness in Home Assistantâs text-to-speech (TTS) implementation. For most of its life, TTS in Home Assistant has required the full response to be generated before any audio can be played. This meant a lot of waiting for multi-paragraph LLM responses, especially with local TTS systems like Piper.
Fixing this required an overhaul of the TTS architecture to allow for streaming. Instead of waiting for the entire audio message to be synthesized before playing, we enabled TTS services within Home Assistant to work with chunks of text (input) and audio (output). As chunks of text are streamed in from an LLM, the TTS service can synthesize audio chunks and send them out to be played immediately.
To demonstrate the benefit of streaming, we asked an LLM to âtell me a long story about a frogâ and timed how long it took to start speaking the (multi-paragraph) response. Without streaming, both Home Assistant Cloud and Piper took more than five seconds to respond! This is long enough to make you wonder if your voice assistant heard you đ With streaming enabled, both TTS services took about half a second to start talking back. A 10x improvement in latency!
New Piper voices
Piper, our homegrown text-to-speech tool, continues to grow with support for several new languages! These new voices were trained from publicly available voice datasets, and are available now in the Piper add-on:
- Daniela (Argentinian Spanish)
- Pratham, Priyamvada, Rohan (Hindi)
- News TTS (Indonesian)
- Maya, Padmavathi, Venkatesh (Telugu)
Want to know what the new voices sound like? You can listen to samples of every available Piper voice or even run Piper entirely within your web browser for free.
If your language is missing from Piper, or you donât like the existing voices for your language, weâre always looking for volunteers to contribute their voices! Please contact us at [email protected]
Conclusion
In the past three years, weâve made great strides with Home Assistant Voice on both the hardware and software fronts. Users today have a wide variety of choices when it comes to voice: from fully local to using the latest and greatest AI to power their smart homes. The great thing about our experimentation with AI is that there are no investors looking for returns, fake money, or ârug-pullsâ. We do everything for you, our community. Weâre in this for the long haul, and want this all to be your choice, keeping you in full control of whether you want to use this technology or avoid the hype completely.
Much of the advanced work done on voice is only possible with the support of our community, especially those who subscribe to Home Assistant Cloud or anyone who has purchased our Home Assistant Voice Preview Edition (both great ways to get started with voice).
This is a companion discussion topic for the original entry at https://www.home-assistant.io/blog/2025/10/22/voice-chapter-11
