Voice PE continue listening after first command possible?
Currently with my Echo I have it configured where I can trigger its wake word and give it a command and it responds. Immediately after that it continues to listen for a new command afterwards for a few seconds. I use this, as an example, to set multiple timers/alarms for the start and end of my lunch break. Is there a way to get Voice PE to do this as well with out having to use the wake word again? Thanks!
Yes, but need adopt to ESPHome first and then you can either use “start_continous” action (default action is “start”) or use an automation to capture the tts_response to determine next step (eg. start list again).
Thank you! I will give that a try!
