Hi, anyone know how to implement a custom wake sound on the HA Voice Preview Edition? I poked around the config but can’t find anything obvious.
Thanks!
Thanks!
The correct way to do this would be to override the filenames using substituions however, at present the filenames are “hard coded” so to speak which makes this difficult without copying the entire configuration, which then means you don’t get updates from the source.
I have flagged an issue relating to this in github, and if the maintainers are open to it, I will also submit the needed code change.
Replace the existing path with your local file (see esphome documentation).
Install the new firmware via esphome.
