Voice PE not handling long replies
I have noticed when my Ollama LLM has a pretty long reply back to me the Voice PE starts great and is talking and after a bit just kills the speaker and led ring while it was still trying to talk. Is there some default delay/shutdown setting I can adjust for this? Or some kind of stay awake command I can embed in its speech? Anything that keeps them from shutting the mic off on my poor LLM :slight_smile: Thanks!
I had exactly the same problem!
Unfortunately, I don’t know exactly how I solved it because in the meantime I found that I had another problem, so all in all, it’s hard for me to say which of the following is the solution to the problem. Either reinstalling Piper or resetting Voice PE to factory settings helped.
While trying to get it working ive reset the voice pe to factory defaults a number of times and doesnt seem to help so I can try piper and see if it helps any. Thanks for the suggestion!
