Voice PE not using custom intents?
I’m trying to work out how to use custom intents, so have started out on what I thought would be an easy one. Seems I under estimated.
I have created my sentences file, /sentenses/en/Jarvis.yaml
language: "en"
intents:
  JarvisTVStatus:
      - sentences:
          - "Jarvis, is the TV on?"
          - "Tell me if the television is on"
          - "Check the status of the TV"
          - "What's the TV doing"
          - "Is someone watching the TV"
          - "What is the status of the TV"
My intent_script.yaml looks like this.
intent_script:
  JarvisTVStatus:
    speech:
      text: >
        {% set tv = states('media_player.sony_xr_50x90s') %}
        {% if tv == 'on' %}
          Yes sir, the TV is currently on and probably showing something you don’t want to admit watching.
        {% elif tv == 'off' %}
          No, the TV is off. All is quiet... for now.
        {% else %}
          Hmm, I can't seem to tell. Perhaps the TV is sulking again.
        {% endif %}
Running a debug I’m getting the following.
init_options:
  start_stage: intent
  end_stage: intent
  input:
    text: What is the status of the TV
  pipeline: 01jtpfw1429t90v4cr5xpeh975
  conversation_id: null
stage: done
run:
  language: en
  conversation_id: 01JV08Z9HFF5ADPK28X9AWCCTJ
  runner_data:
    stt_binary_handler_id: null
    timeout: 300
events:
  - type: run-start
      language: en
      runner_data:
        timeout: 300
    timestamp: "2025-05-11T18:16:01.840317+00:00"
  - type: intent-start
      engine: conversation.home_assistant
      language: en
      intent_input: What is the status of the TV
      device_id: null
      prefer_local_intents: true
    timestamp: "2025-05-11T18:16:01.840389+00:00"
  - type: intent-end
      processed_locally: true
      intent_output:
        response:
          speech:
            plain:
              speech: Sorry, I am not aware of any device called TV
              extra_data: null
          card: {}
          language: en
          response_type: error
            code: no_valid_targets
        continue_conversation: false
    timestamp: "2025-05-11T18:16:01.846173+00:00"
  - type: run-end
    data: null
    timestamp: "2025-05-11T18:16:01.846276+00:00"
intent:
  language: en
  device_id: null
  done: true
  intent_output:
    response:
      speech:
        plain:
          extra_data: null
      card: {}
      language: en
Can someone point me in the right direction? Where have I gone wrong, if I need to provide more information then just say.
Thanks,
Garry
Probably needs the intent sentence file to go under a directory with a name to be as follows (from the Doc):
… create a custom_sentences/<language> directory in your Home Assistant
config
