Voice Preview offset LED start position by 180 degrees
Hello
I’ve mounted my Voice Preview Edition on the wall with the USB cable protruding downwards, this has the unwanted effect of causing timer events to count from the bottom of the LED ring (6 o’clock) instead of the top (12 o’clock).
I don’t believe it’s possible currently (please correct me if I’m wrong), but is it technically feasible to add a configuration option to offset the LED ring by 180 degrees?
Thanks in advance!
