Running the latest 2022.4.7 docker image.
When I try to install the addon, it fails due to not being able to install the pyrate-limiter dependency.
I’ve had the addon running fine some weeks ago. Seems like gcc and python-dev tools are missing?
2022-04-26 19:35:59 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pyrate-limiter>=2.8.0: error: subprocess-exited-with-error
× pip subprocess to install build dependencies did not run successfully.
│ exit code: 1
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-cpython-39
creating build/lib.linux-x86_64-cpython-39/cffi
copying cffi/__init__.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/api.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/commontypes.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/cparser.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/error.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/ffiplatform.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/lock.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/model.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/pkgconfig.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/recompiler.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/vengine_gen.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/verifier.py -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/_cffi_include.h -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/parse_c_type.h -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/_embedding.h -> build/lib.linux-x86_64-cpython-39/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-x86_64-cpython-39/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-x86_64-cpython-39
creating build/temp.linux-x86_64-cpython-39/c
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fomit-frame-pointer -g -fno-semantic-interposition -fomit-frame-pointer -g -fno-semantic-interposition -fomit-frame-pointer -g -fno-semantic-interposition -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python3.9 -c c/_cffi_backend.c -o build/temp.linux-x86_64-cpython-39/c/_cffi_backend.o
error: command 'gcc' failed: No such file or directory
[end of output]
