Volvo On Call device_tracker not updating
Sometime during the last few weeks, the VOC device tracker stopped working in my installation.
I’ve turned on debugging for VOC, and I can see that HASS is receiving position data from VOC. However, the device tracker entity is not updated.
Can anyone point me in a direction where to look?
I have the same issue. I think it was after release 0.56. Maybe @molobrakos can take a look?
Yes, the functionality broke because of changes in core (see https://github.com/home-assistant/home-assistant/issues/10124 for details) It should work in the next version again!
Thanks @molobrakos! I can confirm that manually adding those missing lines of code got the device tracker working again.
I am still using 0.54 and with this version the VOC device_tracker stopped working too.
Although the map shows that the car is not home, the state (home) isn’t changed.
