Volvo On Call error when unlock
Hi! I got the error : Failure when communcating with the server: 500, message=‘Internal Server Error’, url='https://vocapi.wirelesscar.net/customerapi/rest/v3.0/vehicles//unlock
when I try to lock/unlock my car. The status is read without error.
Running 0.110.1
Is there something I have missed in the setup?
Thomas
Hi I have the same using the original respository: https://github.com/molobrakos/volvooncall/issues/62 The maintainer is not responding for a long time, I’ll see if I can have a look at the error and code soon
Call has been changed to only bootunlock, I’ll make a Merge Request. In the meantime you can change unlock into bootunlock in the call
I will try. Thanks!
Unfortunately the request is still failing, do you know how to change in manually to bootunlock in the call?
