Volvo on Call HA integration SSL error
The Volvo on call integration worked fine in March, but stopped working in the beginning of April.
I don’t know the problem what reason is it?
Logger: homeassistant.components.volvooncall.config_flow
Source: components/volvooncall/__init__.py:237
Integration: Volvo On Call (documentation, issues)
First occurred: 11:45:02 (4 occurrences)
Last logged: 11:56:33
Unhandled exception in user step
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 986, in _wrap_create_connection
    return await self._loop.create_connection(*args, **kwargs)  # type: ignore[return-value]  # noqa
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1089, in create_connection
    transport, protocol = await self._create_connection_transport(
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1119, in _create_connection_transport
    await waiter
  File "/usr/local/lib/python3.10/asyncio/sslproto.py", line 534, in data_received
    ssldata, appdata = self._sslpipe.feed_ssldata(data)
  File "/usr/local/lib/python3.10/asyncio/sslproto.py", line 188, in feed_ssldata
    self._sslobj.do_handshake()
  File "/usr/local/lib/python3.10/ssl.py", line 975, in do_handshake
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:997)
  File "/usr/src/homeassistant/homeassistant/components/volvooncall/config_flow.py", line 60, in async_step_user
    await self.is_valid(user_input)
  File "/usr/src/homeassistant/homeassistant/components/volvooncall/config_flow.py", line 137, in is_valid
    await test_volvo_data.auth_is_valid()
  File "/usr/src/homeassistant/homeassistant/components/volvooncall/__init__.py", line 237, in auth_is_valid
    await self.connection.get("customeraccounts")
  File "/usr/local/lib/python3.10/site-packages/volvooncall/volvooncall.py", line 93, in get
    return await self._request(METH_GET, self._make_url(url, rel))
  File "/usr/local/lib/python3.10/site-packages/volvooncall/volvooncall.py", line 68, in _request
    async with self._session.request(
  File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 1138, in __aenter__
    self._resp = await self._coro
  File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 535, in _request
    conn = await self._connector.connect(
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 542, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 907, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1206, in _create_direct_connection
    raise last_exc
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1175, in _create_direct_connection
    transp, proto = await self._wrap_create_connection(
  File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 990, in _wrap_create_connection
    raise ClientConnectorSSLError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorSSLError: Cannot connect to host vocapi-cn.wirelesscar.net:443 ssl:default [[SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:997)]
HI @lumincb
Same here - have you been able to figure out what’s wrong?
