Could you show the content of your it folder and your log output?
It seems you are using the wrong ports in your docker-compose.yaml ![]()
You are mapping the hosts 10500 to the containers port 10500, but inside the container vosk is listening on 10300.
So you need to either change the mapping to 10500:10300 or to 10300:10300 and then point the HA integration to port 10300 ![]()
That’s it:
Wow, a quick test figured out that vosk is faster as faster-whisper, for sure… ![]()
thank you so much!
@Kiesel thanks! I finally have a vosk running on my unraid server with normal (not small) italian model.
But i’m still running on a issue that can’t understand is related to my setting, my language or a vosk general bug.
I created a file both in the folder “sentences” of the container and in “custom_sentences” within home assistant with “skip_words” to avoid some mismatch but it does not work.
@brunopiras maybe you also faced this?
Below details:
content of _common.yaml :
skip_words:
- “e”
- “a”
debug log within the container:
DEBUG:root:Transcript for client 988532886902325: e dove si trova irene
DEBUG:root:Client disconnected: 988532886902325
DEBUG:root:Client connected: 988548792181924
DEBUG:root:Loaded recognizer in 0.00 second(s)
DEBUG:root:Transcript for client 988548792181924: e dove si trova irene
DEBUG:root:Client disconnected: 988548792181924
DEBUG:root:Client connected: 988559958834937
DEBUG:root:Transcript for client 988559958834937: e dove si trova marco
DEBUG:root:Client disconnected: 988559958834937
DEBUG:root:Client connected: 988575006419908
as you can se “e” is still detected and make the intent fail.
Any tip?
Sorry, I don’t use the skip words feature myself. Did you have a chance to ask on vosks github?
no but maybe I’ll ask on rhasspy vosk because I think that the wyoming protocol of vosk may be different from original vosk.
Your post was at the top of Google when I researched so I figured that I would share the solution I ended up with. This uses the Vosk image from Rhasspy:
services:
vosk:
image: rhasspy/wyoming-vosk
command: >-
--correct-sentences 0.0
--preload-language en
--model-for-language en vosk-model-small-en-us-0.15
--debug
--limit-sentences
--download-dir /data
--database-dir /data
--data-dir /data
--data-dir /models
--sentences-dir /sentences
volumes:
- data:/data
- ./sentences:/sentences:ro
- ./models:/models:ro
ports:
- 10300:10300
restart: unless-stopped
