VSCode add-on and ESPHome add-on
Trying to edit ESPHome project with VSCode and get the following error in VSCode “Could not execute ESPHome. Make sure you can run ESPHome from the command line.” Per instructions, Per VSCode documentation I have added leave_front_door_open: true in ESPHome add-on Configuration and Host 6052 in ESPHome add-on Network settings. Not sure, if this related, but I can’t access homeassistant.local:8123, but I can access homeassistant:8123 or by using the actual ip address.
