VTherm + SONOFF TRVZB - Z2M configuration?
Hi All!
I’m just starting my adventure with HA, and really with the whole “smart home” concept, so my question is probably very simple and silly :smiley:
I have a SONOFF TRVZB + external Xiaomi sensors.
I have the TRV connected to HA via Z2M, and the sensors via BLE.
I installed VTherm, everything is set up, and everything seems to be OK – the control works, it opens and closes, the UI also works well (in terms of setting the temperature and reading the current one), but I can’t stop thinking about the Z2M itself – do I need to set something else there, or will VTherm take care of it itself?
I mean, for example, “Temperature sensor” where it is always set to ‘internal’ or the “Open window” option (here it is OFF, I turned it on in VTherm - I understand that now it is simply decided by the external sensor connected to VTherm?
Additionally, after restarting HA, the entire VTherm stops working (turns off?) and I have to change the set temperature in the thermostat for it to “kick in.”
I would appreciate your help :slight_smile:
