Servus, I have created a vzlogger.con file and put it in the folder the folder “config”.
Here is the content:
“verbosity”: 10,
“retry”: 30,
“local”: {
“enabled”: false,
“port”: 8081,
“index”: true,
“timeout”: 0,
“buffer”: -1
“meters”: [
“enabled”: true,
“allowskip”: false,
“protocol”: “d0”,
“device”: “/dev/ttyUSB0”,
“aggtime”: -1,
“interval”: 10,
“pullseq”: “2F3F210D0A”, // “/?!\r\n” = 2F 3F 21 0D 0A
“ackseq”: “063034300D0A”, //needs to be in accordance to parameter ‘baudrate_read’
//“auto” for auto detection
“baudrate”: 300,
“baudrate_read”: 4800,
“baudrate_change_delay”: 300,
“parity”: “7e1”,
“use_local_time”: false,
“read_timeout”: 10, //?? 2200ms according to manual?
“dump_file”: “/config/D0_pullSeq.txt”,
“channels”: [
“identifier”: “1.7.0”, //Positive active instantaneous power (A+) [kW]
“uuid”: “00000000-0000-0000-0000-000000000000”,
“api”: “influxdb”,
“host”: “http://localhost:8086”,
“database”: “vzlogger”,
“measurement_name”: “vz_measurement”,
“duplicates”: 600,
“username”: “”,
“password”: “”
“identifier”: “1.8.1”, //Positive active energy (A+) in tariff T1 [kWh]
“api”: “influxdb”,
“duplicates”: 600,
“username”: “”,
“password”: “”
“identifier”: “2.8.1”, //Negative active energy (A+) in tariff T1 [kWh]
“api”: “influxdb”,
“duplicates”: 600,
“username”: “”,
“password”: “”
In the vzlogger protokoll I get this:
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.128, value=135.381, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.127, value=132.010, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.126, value=129.236, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.125, value=126.996, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.124, value=121.648, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.123, value=118.335, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.122, value=115.298, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.121, value=112.545, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.120, value=110.467, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.119, value=107.505, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.118, value=101.144, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=3.8.117, value=92.337, unit=)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=4.8.1, value=1188.562, unit=kvarh)
[Aug 15 01:22:43][d0] Parsed reading (OBIS code=4.8.131, value=1175.069, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.130, value=1146.070, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.129, value=1112.690, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.128, value=1086.346, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.127, value=1059.731, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.126, value=1025.498, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.125, value=989.925, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.124, value=957.524, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.123, value=923.520, unit=)
[Aug 15 01:22:44][d0] Failed to parse obis code (C.60.5.1)
[Aug 15 01:22:44][d0] Failed to parse obis code (C.60.5.2)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.1.8.1)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.1.8.2)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.1.8.3)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.1.8.4)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.1.8.5)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.1.8.6)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.2.8.1)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.2.8.2)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.2.8.3)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.2.8.4)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.2.8.5)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.122, value=889.667, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.121, value=857.148, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.120, value=824.492, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.119, value=792.462, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.118, value=765.758, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=4.8.1*17, value=728.304, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=0.9.1, value=01:22:44, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=0.9.2, value=23-08-15, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=0.2.0, value=07.000 0998 E354, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=C.60.5.1, value=D.01, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=C.60.5.2, value=20.023 0998 1189, unit=)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=1.7.0, value=2.825, unit=kW)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=2.7.0, value=0.904, unit=kW)
[Aug 15 01:22:44][d0] Parsed reading (OBIS code=3.7.0, value=0.607, unit=kvar)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=4.7.0, value=0.657, unit=kvar)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=14.7, value=49.99, unit=Hz)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=32.7, value=239.0, unit=V)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=52.7, value=238.6, unit=V)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=72.7, value=240.2, unit=V)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=31.7, value=5.68, unit=A)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=51.7, value=6.97, unit=A)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=71.7, value=3.98, unit=A)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=91.7, value=6.25, unit=A)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=81.7.4, value=-28.9, unit=Deg)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=81.7.15, value=10.1, unit=Deg)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=81.7.26, value=160.8, unit=Deg)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=81.7.1, value=119.9, unit=Deg)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=81.7.12, value=119.7, unit=Deg)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=81.7.20, value=120.2, unit=Deg)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=32.36.0, value=0, unit=)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=52.36.0, value=0, unit=)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=72.36.0, value=0, unit=)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=32.32.0, value=0, unit=)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=52.32.0, value=0, unit=)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=72.32.0, value=0, unit=)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=C.2.1, value=22-07-22 12:42, unit=)
[Aug 15 01:22:45][d0] Parsed reading (OBIS code=C.7.0, value=5, unit=)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.7.1, value=0, unit=)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.7.2, value=0, unit=)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.7.3, value=0, unit=)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.C.1, value=0, unit=)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.1.8.1, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.1.8.2, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.1.8.3, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.1.8.4, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.1.8.5, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.1.8.6, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.2.8.1, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.2.8.2, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.2.8.6)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.2.8.3, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.2.8.4, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Parsed reading (OBIS code=C.2.8.5, value=0.0, unit=kW)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.60.4.1)
[Aug 15 01:22:46][d0] Failed to parse obis code (C.60.4.2)
[Aug 15 01:22:47][d0] Failed to parse obis code (C.60.4.3)
[Aug 15 01:22:47][d0] Failed to parse obis code (C.60.4.4)
[Aug 15 01:22:47][d0] Failed to parse obis code (C.60.4.5)
[Aug 15 01:22:47][d0] Failed to parse obis code (C.60.4.6)
[Aug 15 01:22:47][d0] Failed to parse obis code (C.60.4.7)
[Aug 15 01:22:47][d0] Failed to parse obis code (C.60.4.11)
[Aug 15 01:22:47][d0] Failed to parse obis code (C.60.4.13)
[Aug 15 01:22:47][d0] Failed to parse obis code (C.60.4.14)
[Aug 15 01:22:47][d0] Failed to parse obis code (C.60.4.15)
[Aug 15 01:22:47][d0] Failed to parse obis code (C.60.4.16)
Not sure what next.
Kind regards
Ed
