You had replied to me in another (old) topic but then deleted your post.
The contents of that deleted post are still available (it takes about 24 hours before it’s permanently deleted). You had posted a trace and I have copied it here.
Click to reveal the trace
"trace":{
"last_step":"action/0/else/1",
"run_id":"0d7f08e7347df84c42ed54d20ae645c3",
"state":"stopped",
"script_execution":"cancelled",
"timestamp":{
"start":"2026-02-18T11:16:24.976945+00:00",
"finish":"2026-02-18T11:25:59.816814+00:00"
"domain":"automation",
"item_id":"1759740068221",
"trigger":null,
"trace":{
"trigger":[
"path":"trigger",
"timestamp":"2026-02-18T11:16:24.977123+00:00",
"changed_variables":{
"this":{
"entity_id":"automation.heizlufter_hobby",
"state":"on",
"attributes":{
"id":"1759740068221",
"last_triggered":"2026-02-17T19:46:50.692170+00:00",
"mode":"restart",
"current":0,
"friendly_name":"Heizlüfter Hobby"
"last_changed":"2026-02-18T10:11:13.076264+00:00",
"last_reported":"2026-02-18T10:11:13.076264+00:00",
"last_updated":"2026-02-18T10:11:13.076264+00:00",
"context":{
"id":"01KHR3PZHM8Q8GRPQM2MJ3QF8B",
"parent_id":null,
"user_id":null
"trigger":{
"platform":null
"action/0":[
"path":"action/0",
"timestamp":"2026-02-18T11:16:24.978231+00:00",
"context":{
"id":"01KHR7EBRGV5D0395X5T5F2HTQ",
"parent_id":"01KHR7EBRGKM3RHND04NN75BWB",
"user_id":null
"wait":{
"remaining":5400,
"completed":false,
"trigger":null
"result":{
"choice":"else"
"action/0/if":[
"path":"action/0/if",
"timestamp":"2026-02-18T11:16:24.978859+00:00",
"result":{
"result":false
"action/0/if/condition/0":[
"path":"action/0/if/condition/0",
"timestamp":"2026-02-18T11:16:24.979108+00:00",
"result":{
"result":false
"action/0/if/condition/0/entity_id/0":[
"path":"action/0/if/condition/0/entity_id/0",
"timestamp":"2026-02-18T11:16:24.979307+00:00",
"result":{
"result":false,
"state":19.3,
"wanted_state_above":20
"action/0/else/0":[
"path":"action/0/else/0",
"timestamp":"2026-02-18T11:16:24.980123+00:00"
"action/0/else/1":[
"path":"action/0/else/1",
"timestamp":"2026-02-18T11:16:25.078915+00:00",
"wait":{
"remaining":5400,
"completed":false,
"trigger":null
"result":{
"result":false,
"state":19.3,
"wanted_state_above":21
"config":{
"alias":"Heizlüfter Hobby",
"description":"Schaltet den Heizlüfter ein, wenn die Temperatur im KG Hobbyraum unter 20° C sinkt.",
"triggers":[
"device_id":"bb7849dff6beb98edc930c62d947175c",
"domain":"climate",
"entity_id":"31d3a67a7b76f01e7d25abe6c1fe3258",
"type":"current_temperature_changed",
"trigger":"device",
"below":20
"domain":"climate",
"trigger":"device",
"below":19
"domain":"climate",
"trigger":"device",
"below":18
"trigger":"homeassistant",
"event":"start"
"conditions":[
"condition":"and",
"conditions":[
"condition":"state",
"entity_id":"input_boolean.verreist",
"state":"off"
"actions":[
"if":[
"condition":"numeric_state",
"entity_id":"sensor.kg_heizung_hobby_int0000012_temperatur",
"above":20
"then":[
"type":"turn_off",
"continue_on_error":true,
"device_id":"28cfcf340f1885db4184c00975b3acfa",
"entity_id":"4caeb68f0e488aefe23bff64b1ec3db7",
"domain":"switch"
"else":[
"type":"turn_on",
"domain":"switch"
"wait_for_trigger":[
"domain":"climate",
"trigger":"device",
"above":21
"continue_on_timeout":true,
"timeout":{
"hours":1,
"minutes":30,
"seconds":0,
"milliseconds":0
"repeat":{
"while":[
"condition":"device",
"type":"is_on",
"domain":"switch"
"sequence":[
"type":"turn_off",
"domain":"switch"
"delay":{
"hours":0,
"minutes":1,
"seconds":0,
"milliseconds":0
"delay":{
"hours":0,
"minutes":30,
"seconds":0,
"milliseconds":0
"action":"automation.trigger",
"metadata":{
"target":{
"data":{
"skip_condition":true
"mode":"restart"
"blueprint_inputs":null,
"context":{
"user_id":null
"logbookEntries":[
"name":"Heizlüfter Hobby",
"message":"triggered",
"source":null,
"context_id":"01KHR7EBRGV5D0395X5T5F2HTQ",
"when":1771413384.977368
"state":"on",
"entity_id":"switch.ug_htr_zb_steckdose_trockner_alt",
"icon":"mdi:power-socket-de",
"when":1771413385.0775886,
"context_event_type":"automation_triggered",
"context_domain":"automation",
"context_name":"Heizlüfter Hobby",
"context_message":"triggered",
"context_entity_id":"automation.heizlufter_hobby"
That mode means that if the automation is waiting for something to happen in its actions section (like a wait_for_trigger) it will automatically abort and restart if its main triggers detect changes to the values they are monitoring.
