Wait_for_trigger: Trigger ID field available but not functional - Bug or UI issue?
Title: wait_for_trigger: Trigger ID field available but not functional - Bug or UI issue?
Description:
I discovered an issue with wait_for_trigger in automations where the id field is available in the UI and YAML configuration, but the trigger IDs are not actually accessible/functional when the wait trigger fires.
Steps to reproduce:
  1. Create an automation with a wait_for_trigger block
  2. Add multiple triggers with different id values:
wait_for_trigger:
  - trigger: state
    entity_id: input_select.rollo_stand
    to: Offen
  - trigger: state
    to: Sonnenschutz
  1. Try to use the trigger ID in subsequent actions (e.g., {{ wait.trigger.id }})
Expected behavior:
Since the id field is available in the UI and accepts values in YAML, I expected to be able to:
  • Access the trigger ID that fired via wait.trigger.id
  • Use different IDs to determine which trigger condition was met
Actual behavior:
The trigger IDs set in wait_for_trigger are not accessible or functional. The id field appears to have no effect, unlike the id field in regular automation triggers where it works as expected.
Question:
Is this a bug, or is the id field intentionally non-functional in wait_for_trigger? If it’s intentionally not supported, should the UI field be removed to avoid confusion?
Environment:
  • Home Assistant Version: 2025.10.1
  • Installation type: Home Assistant OS
Thank you for clarifying!
According to the documentation, yes wait_for_trigger should have a valid variable for {{wait.trigger.id}} as long as the wait did not time out.
So it is a bug? Because the trigger id is not available in conditions after the wait trigger
Maybe. Share your actual config that shows how you discovered this “bug”.
Here the automation where I saw the problem
alias: Button Kinderzimmer Steuerung - Bug Example
description: Example showing non-functional trigger IDs in wait_for_trigger
triggers:
  - domain: mqtt
    device_id: cc1589c400498b3bb7b6643fddfbbcb1
    type: action
    subtype: double
    trigger: device
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Rollo-hoch
          - condition: state
            state: Geschlossen
        sequence:
          - parallel:
              - action: homeassistant.turn_off
                metadata: {}
                data: {}
                  entity_id: group.sleepmode_all
              - action: input_boolean.turn_off
                metadata: {}
                data: {}
                  entity_id: input_boolean.kinderzimmer_zahlen
          # This wait_for_trigger has trigger IDs that are NOT functional
          - wait_for_trigger:
              - trigger: state
                to: Offen
              - trigger: state
                to: Sonnenschutz
              - trigger: state
                to: Sonnenschutz Seite
              - trigger: state
                to: Sonnenschutz Vorne
            timeout:
              hours: 2
            continue_on_timeout: false
          # Trying to use the trigger IDs here DOES NOT WORK
          - choose:
              - conditions:
                sequence:
                  - action: cover.open_cover
                    metadata: {}
                    data: {}
                      area_id: gastezimmer_1
              - conditions:
                sequence:
                  - action: cover.set_cover_position
                    metadata: {}
                      position: 25
                      entity_id: cover.kind_rollo
              - conditions:
                sequence:
                    metadata: {}
                      position: 30
              - conditions:
                sequence:
                    metadata: {}
                      position: 35
mode: restart
Depending on the trigger id I wanted to trigger different things after the wait_for_trigger
You can’t do this to test:
          - choose:
              - conditions:
That will check trigger.id not wait.trigger.id. i.e. you are checking the main automation triggers, not the wait triggers.
You need to use a template condition:
          - choose:
              - conditions:
                  - condition: template
                    value_template: "{{ wait.trigger.id ==  'zu-offen' }}"
Also this is a bad idea:
            timeout:
              hours: 2
You should not be waiting that long in an automation.
Good to know it is possible, bad it is not available from the UI. But thanks for clarification.
