Wake on lan help
ok guys I need some help in the switch :
 - platform: wake_on_lan
     mac_address: "1C:xx:xx:26:xx:xx"
     host: "xxx.xxx.x.xxx"
     broadcast_adress: "xxx.xxx.0.xxx
the host is for the router IP and broadcast is for the PC IP?
The broadcast address is the network broadcast address, but you can leave it out since there’s a sensible default.
Adding to previous reply: the host is the IP of the device/PC you want to wake up. You shouldn’t need to set that.
Remember to activate WoL on the device (PC bios setting) too.
