Wake Up Command
Is there a way to issue a wake-up command to battery powered sensors when HA reboots? I have two Aeotec Door/Window sensors, that since customizing them so that they show Open/Closed rather than On/Off, that show an Open status whether they are or not. One, in particular, was fine until I customized the sensor as stated. I do not see any differences in the customizing and out of all the Aeotec Door/Window Sensor 6’s I have, they are the only two that respond this way.
They are always in sleep mode so I thought I would see if I could force them to wake up when HA reboots and see if that helps the status. If I go open and close the window or door for these two sensors, they read and show correct status from there out until I reboot HA again.
