Wall display recommendations?
Hi everyone, I was looking for some good wall-mounted wallpanels but I couldn’t find any good options.
My requirements are:
  • It doesn’t have a battery
  • It needs to have a good performance (showing 4 camera feeds)
  • Preferably runs Linux instead of Android
  • Fits into a 503 electrical box: a Raspberry pi doesn’t fit.
  • Is sold in Europe (Italy)
  • Has WiFi
  • The screen must be 10" or more
I would prefer to avoid tablets with batteries because modifying it to remove the battery is tedious.
503 wall boxes are ubiquitous in Italy but rarer elsewhere, so it’s very likely that no “ready to install” solutions will be available.
How do you plan to power it? How much budget do you plan to set aside for this?
Low budget: hide a WiFi smart relay and a power adapter, buy or 3d print a frame for a tablet
High budget: android based display for conference rooms but you’ll need to craft something to fix it to the wall
Crestron TSW units may be available to you.
Wallbox size may not be a Concern since most units mount ON Wall not IN wall. Wallbox is used mostly for pre wire and holes are universal to mounts or can be added without impact
Hello wolly7,
Welcome to the Home Assistant Forum!
This is asked at least once a week.
Check back at other posts. Put this in a search engine…
site:community.home-assistant.io Wall display recommendations
This might help also in the future: How to help us help you - or How to ask a good question
