Wall panel - removing weather error
Hi All
I’ve installed the Wall Panel add on, which looks great… I’ve got local pictures showing as a slideshow no problem… but I can’t get rid of the error saying weather entity isn’t found… I’m not interested in showing the weather over the top… is there a way to remove it?
I’ve
  1. checked the different parameters available but there doesn’t seem to be one to not show weather.
  2. I’ve deleted the weather card section in the wallpanel.js resource file
neither made any difference.
thanks
Ask the addon author to fix their stuff to work with the current way HA does forecast. (Most likely problem)
