Hello everyone,
I am looking for the OCCP settings that I need to enter in the Vestel04 so that it works fully with the OCCP integration in HA.
I used to have this connected via EVCC. This even worked for controlling the charging current.
However, as I want to do everything with HA, I switched to OCCP integration.
Some time ago, everything worked except for setting the charging current. The only noticeable thing was that after switching on charging, it took quite a long time (30 seconds to a minute or so) until the wallbox also delivered the ‘Current Import’ and the ‘Power Active Import’ to HA. Charging was done immediately, I could see that on the wallbox and on the power consumption in the HA. Just not on the wallbox data in HA.
I had found the OCCP settings for the Vestel04 somewhere on the Internet at the time and unfortunately I can no longer find them.
I had to reset the box to factory settings because it kept losing the WLAN. It’s OK again now. I have now made the basic TCP settings for OCCP.
I can now control the wallbox via the HA and get almost all the values, but not all of them.
I’m missing ‘Current Import’ and ‘Power Active Import’ during charging.
And reducing ‘Maximum Current’ does not change anything when charging. It is always charged with maximum current after switching on.
It would be nice if someone could help me with this
Best regards Johannes
