Wallpanel Integration
This is a fully Kiosk alternative but with a direct camera stream, so you can add it to motioneye. (Freeware, Motion detect, face detect etc)
A Integration for that whould be nice.
It has mqtt with discovery, so not sure what else you would want.
I think the mqtt discovery was only for Batterie state, brightness etc.
Commands you need to publish via Services. Z.b. Camera activ
Add the camera to HA then. Generic Camera - Home Assistant
This was one example from many Commands. Check command list Website. ( I think you dont know the Tool)
A Integration would be the best.
I do know it.
I think anything that is documented here MQTT and HTTP commands | WallPanel can be so easily incorporated into home assistant that it hardly seems worth it.
I dont know how to create that for mqtt with Buttons and switched etc…
I have tried but without sucess. For normalos IT IS Not so easy :see_no_evil:
The wallpanel docs are full of examples.
I know and did not work as i tested
It did for me. I literally set it up to respond to this thread.
Can you share please your example/test?
There is not much to share. I assume you have a mqtt broker installed and the mqtt integration set up in ha.
  1. Install wallpanel
  2. Set up mqtt on the wallpanel, you probably need the address, username and password.
That’s it. You get these things in HA.
If you want other things integrated, be specific.
This yes, but i said the commands not the sensors. :slight_smile:
Be specific. What command, just as an example.
Camera activ for example
I wanna activate the camera only when No one is at Home and the door sensor triggered
Does the camera.turn_off and camera.turn_on services not work?
I need to disable it directly in wallpanel because the Batterie usage ist so high.
The Service ist only for the homeassistent camera internal, when im right
I am trying to use the wallpanel qr code reader feature to read the qr code for my alarm from the cards and it works conditionally. Every now and then it happens that the reading of the qr code stops working and does not work until I restart the wallpanel application. Anyone else having similar issues?
Been using Wallpanel for a while now as it’s faster than FullyKiosk displaying my dashboards.
I just noticed that the MQTT message it sends for state is a bit wierd…
{"currentUrl":"https:\/\/myURL:8123\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/fire-panel\/phome","screenOn":false,"camera":true,"brightness":192}
The currentURL has the root fire-panel repeated over and over before the actual page phome being displayed.
I can, and do on screen timeout, force it back to phome through the automation action…
action: mqtt.publish
metadata: {}
  payload: "{\"url\":\"https://MyURL:8123/fire-panel/phome\"}"
  topic: wallpanel/mywallpanel/command
So why is it reporting it back with all those repeats?
