Want to refresh data in flex-table-card after tap action
I have a flex-table-card that sources data from a script, and allows for updates via tap actions. (The data happens to be stored/persisted in a local todo list.) When I do a tap action, that updates the persistent data, but the flex-table-card doesn’t know this has happened. I’d like to inform the card to re-retrieve the data i.e. to rerun the script that is the data source, after a tap action that I know does updates.
I remembered to have tried this quite a while ago but no longer sure if it is working … did you try this (from the card’s docu)?
flex-table-card/docs/example-cfg-services.md at master · custom-cards/flex-table-card
Thank you for the pointer!
I tried adding another level to the script response data but then the data did not come across, and it the dashboard still didn’t update when the todo lists was updated externally. Here’s what I’m trying:
          - type: custom:flex-table-card
            entities:
              - todo.shows_watch_list                  <--- with this one we get extra rows of undefined..
                                                      <--- so usually I use entities: [ ]
            action: script.getshows
              entity_id:
                - todo.shows_watch_list                <--- doesn't seem to update when todo is modifed
            columns:
              - name: Test
                data: items.summary
              - name: Title
                data: items.entity_id
                tap_action:
                  action: perform-action
                  perform_action: script.markshowwatched
                    entity_id: items.entity_id
                    title: cell[0]
              - name: Last
                data: items.last
              - name: Service
                data: items.service
              - name: Profile
                data: items.profile
              - name: Ready
                data: items.current
Here’s the script return value, variable “response”:
response:
  todo.shows_watch_list:                 <--- I added this level as per suggestion, but no joy
                                         <--- suggestion I read was to make the top-level look like todo.getitems
                                         <--- without it, the data comes across into the flex-table-card
    items:
      - entity_id: The Pitt
        last: 25-12-18
        service: HBO
        profile: Erik
        current: 'yes'
        next: '2026-01-08'
      - entity_id: Madmen
        last: 25-12-13
        next: now
        service: Paramount+
        profile: Carol
        current: 'no'
So, I’m missing something(s), obviously!
(Clearly my data as returned by script is not the same as raw todo.getitems, but read it doesn’t have to be identical…)
I am not sure anylonger how it worked in the past and I donot have a working example.
I did do something different to cover the issue with ‘updated externally’. I created a scripted sensor for my shopping-list which updates when the file changes and this allows me to trigger things too…and from what I read from the docu, the flex-table-card needs an entity that gets updated to refresh itself
Finally got it to work!
Key was putting the same entity id in both places, entities list as well as target. Further, it shouldn’t be the todo list for the entity since that doesn’t update its state on change. (Todo list state is a count of the total number of todo items; doesn’t change when modify individual items.)
            action: script.getshows_duplicate
            entities:
              - input_boolean.flextablecardhelper
              entity_id:
            columns:
              - name: Title
My “tap action” script toggles this boolean helper after updating the todo list cell, and with this, flex-table-card updates.
When the entities and target are not both present, it will add undesired rows due to the entities list not being empty, but apparently when the same id is supplied for both objects, it doesn’t add those unwanted rows.
Further, it seems that the extra level of JSON is required to be returned by the script (here getshows_duplicate), but the name of the extra level returned by the script doesn’t seem to matter. None-the-less, I choose to use the entity_id passed:
variables:
  response:
    '{{entity_id[0]}}':
      items: '{{ shows }}'
But I had hard coded the key as an old id for the second level and it still worked! In fact I had this:
variables:
  response:
    entity_id[0]:
which is a typo (didn’t evaluate that JSON key as template but instead literal text), and updating the card still worked!
Thanks again for your help!
