I'm wondering if there is a way to simplify the template yaml below?
I have a pressure sensor in a water tank. It provides a voltage, sensor.tankd_adc, from which I calculate water depth (and from that, I calculate %full & volume).
This template works (it's in a template.yaml file) but is there a way to use iif?
- sensor:
- name: hTankD
unit_of_measurement: "m"
device_class: distance
unique_id: 10240032
state: >
{% set Vi = states('sensor.tankd_adc') | float(default=0) %}
{% if Vi > 5.81 %}
{% set Vi = 5.81 %}
{% endif %}
{{ (Vi * 0.30981 + 0.06) | round(3) }}
If your sensor value is above 5.81 then the min (minimum) filter selects 5.81. If your sensor value is below 5.81 then the minimum filter selects that value.
1.86 is the result of the calculation with 5.81 as the input. That might be more readable for you in future if you recognise 1.86m as a physical tank dimension more than you recognise 5.81V as the ADC output.
