Hello, i’m using the ‘WAQI’ component with the awesome templates sensors from the great @renemarc and unfortunately since Monday night they suddenly stopped working.
The ‘WAQI’ stations are loading fine, but the templates are not.
Here is the complex code from @renemarc:
## WAQI ##
- platform: waqi
token: !secret waqi_token
locations: !secret waqi_location
stations: !secret waqi_stations
## WAQI TEMPLATE ##
# WAQI: Stations
sensors:
aqi_stations:
friendly_name: Stations AQI
icon_template: mdi:radar
entity_id:
- sensor.time_quarterly
value_template: >-
{% set attribute = 'name' %}
{% set max_hours_behind = 4 %}
{% set cutoff = (as_timestamp(now())|int - max_hours_behind * 60 * 60) | timestamp_local %}
{% set stations = states | selectattr('entity_id', 'in', state_attr('group.waqi', 'entity_id'))
| rejectattr('attributes.time', 'lt', cutoff)
| selectattr(attribute)
| map(attribute=attribute)
| join('|') %}
{% if stations %}
{{ stations }}
{% endif %}
aqi_stations_count:
friendly_name: Stations AQI Nombre
value_template: >-
{% set stations = states('sensor.aqi_stations') %}
{% if stations != '' %}
{{ stations.split('|') | length }}
{% else %}
0
{% endif %}
# WAQI: Average
sensors:
aqi:
friendly_name: Qualité de l'air
icon_template: mdi:chemical-weapon
entity_id:
value_template: >-
{% set attribute = 'state' %}
| map('float')
| list %}
{% if stations %}
{{ (stations|sum / stations|length) | round }}
{% else %}
unknown
{% endif %}
aqi_friendly:
value_template: >-
{% set index = states('sensor.aqi') | float(-1) %}
{% if index > 300 %}
Hasardeux
{% elif index > 200 %}
Très mauvais
{% elif index > 150 %}
Mauvais
{% elif index > 100 %}
Mauvais pour les personnes sensibles
{% elif index > 50 %}
Modéré
{% elif index >= 0 %}
Bon
{% else %}
unknown
{% endif %}
# WAQI: Particulate matter 2.5μm
sensors:
aqi_particles:
friendly_name: PM2.5
icon_template: mdi:chart-bubble
unit_of_measurement: 'PPM'
entity_id:
value_template: >-
{% set attribute = 'attributes.pm_2_5' %}
| map('float')
| list %}
{% if stations %}
{% else %}
unknown
{% endif %}
aqi_particles_friendly:
value_template: >-
{% set pm25 = states('sensor.aqi_particles') | int(-1) %}
{% if pm25 > 300 %}
Hasardeux
{% elif pm25 > 200 %}
Très mauvais
{% elif pm25 > 150 %}
Mauvais
{% elif pm25 > 100 %}
{% elif pm25 > 50 %}
Modéré
{% elif pm25 >= 0 %}
Bon
{% else %}
unknown
{% endif %}
# WAQI: Nitrogen dioxide
sensors:
aqi_nitrogen_dioxide:
friendly_name: Dioxyde d'azote
icon_template: mdi:car
entity_id:
value_template: >-
{% set attribute = 'attributes.nitrogen_dioxide' %}
| map('float')
| list %}
{% if stations %}
{% else %}
unknown
{% endif %}
aqi_nitrogen_dioxide_friendly:
value_template: >-
{% set nox = states('sensor.aqi_nitrogen_dioxide') | int(-1) %}
{% if nox > 300 %}
Hors des mesures
{% elif nox > 200 %}
Très mauvais
{% elif nox > 150 %}
Mauvais
{% elif nox > 100 %}
{% elif nox > 50 %}
Modéré
{% elif nox >= 0 %}
Bon
{% else %}
unknown
{% endif %}
# WAQI: Ozone
sensors:
aqi_ozone:
friendly_name: Ozone
icon_template: mdi:earth
entity_id:
value_template: >-
{% set attribute = 'attributes.ozone' %}
| map('float')
| list %}
{% if stations %}
{% else %}
unknown
{% endif %}
aqi_ozone_friendly:
value_template: >-
{% set ozone = states('sensor.aqi_ozone') | int(-1) %}
{% if ozone > 300 %}
Hasardeux
{% elif ozone > 200 %}
Très mauvais
{% elif ozone > 150 %}
Mauvais
{% elif ozone > 100 %}
{% elif ozone > 50 %}
Modéré
{% elif ozone >= 0 %}
Bon
{% else %}
unknown
{% endif %}
# WAQI: Sulphur dioxide
sensors:
aqi_sulphur_dioxide:
friendly_name: Dioxyde de soufre
icon_template: mdi:factory
entity_id:
value_template: >-
{% set attribute = 'attributes.sulfur_dioxide' %}
| map('float')
| list %}
{% if stations %}
{% else %}
unknown
{% endif %}
aqi_sulphur_dioxide_friendly:
value_template: >-
{% set so2 = states('sensor.aqi_sulphur_dioxide') | int(-1) %}
{% if so2 > 300 %}
Hors des mesures
{% elif so2 > 200 %}
Très mauvais
{% elif so2 > 150 %}
Mauvais
{% elif so2 > 100 %}
{% elif so2 > 50 %}
Modéré
{% elif so2 >= 0 %}
Bon
{% else %}
unknown
{% endif %}
If anyone have an idea on what is going on, i will be glad to know.
Thanks.
