Warning during OTA in Esphome (dev) latest version
I am working towards making a weighing scale using for load cells in bridge configuration using a green colored HX711 Amp board. I have made a link from E- to GND and soldered connector bases as shown in the pic. when I upload the code using OTA Iget a warning as below
INFO Reading configuration /config/esphome/weighingscale.yaml...
INFO Generating C++ source...
INFO Compiling app...
INFO Running:  platformio run -d /config/esphome/weighingscale
<s>Obsolete PIO Core v4.3.3 is used (previous was 4.3.4)</s>
<s>Please remove multiple PIO Cores from a system:</s>
<s>https://docs.platformio.org/page/faq.html#multiple-pio-cores-in-a-system</s>
Processing weighingscale (board: esp12e; framework: arduino; platform: [email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
PACKAGES:
 - framework-arduinoespressif8266 2.20502.0 (2.5.2)
 - tool-esptool 1.413.0 (4.13)
 - tool-esptoolpy 1.20600.0 (2.6.0)
 - toolchain-xtensa 1.40802.2 (4.8.2)
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.2
|   |-- <ESP8266WiFi> 1.0
|-- <ESP8266mDNS> 1.2
|-- <ESPAsyncWebServer-esphome> 1.2.6
|   |-- <Hash> 1.0
|-- <DNSServer> 1.1.1
Retrieving maximum program size /data/weighingscale/.pioenvs/weighingscale/firmware.elf
Checking size /data/weighingscale/.pioenvs/weighingscale/firmware.elf
RAM:   [=====     ]  46.3% (used 37920 bytes from 81920 bytes)
Flash: [====      ]  38.5% (used 402096 bytes from 1044464 bytes)
========================= [SUCCESS] Took 9.95 seconds =========================
The warning about obsolete PIO Core has been highlighted as strike through.
How do I remove multiple PIO cores as stated in this.
Did you read the link? What type of HA installation do you have?
@Troon, thanks for the response. Yes I did google multiple PIO cores, I was behind the cuve. I have Home assistant on a SD card with ESPhome (dev) as an addon. Platform IO is loaded where is not known to me. It is for this reason I have put up this querry here. Perhaps a more lucid approach will be helpful.
Best Regards…
I have the same warnings, on HA 0.112.2 and dev version of ESPHOME
Actually its in ESPHOME’s docs for setting up a SONOFF, guess its an old issue
There must be a way of removing duplicate files…
Many learned folks in the community. Will get a direction!
Wonder if it is only the dev version of esphome ?
It is in the normal esphome too. I changed to esphome dev in the hope that I would get rid of this but no luck, an issue has been raised but no luck yet.
