I’m attempting to install Home Assistant with the All-in-One script on a Raspberry P3 with Pixi. The Pi crashes/reboot after the below (replicated 6 times). Thoughts?
Warning: sudo() received nonzero return code 1 while executing ‘ln -s /usr/local/lib/python3.4/dist-packages/cec /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages’!
same here.
i’ve spent 5 days trying to install without errors, so far no success.
here is also some ticket https://github.com/eclipse/mosquitto/issues/529 not sure if those are related at all.
