Hi
I have been using the waste collection schedule for a while now 2.7.0. Today its failed after a calendar update. On attempting to reconfigure it throws the error: The source returned an invalid response: “‘NoneType’ object has no attribute ‘strip’”. Please check the provided arguments and try again.
The council details are correct, any advice please, Regards Pete
Did you check under GitHub · Where software is built
If your area is affected? Also it may be handy to post the log entries for this. Sometimes the final error is due to not getting something right much further up the stream.
I seem to be running the latest version and it was functional . My area Blackpool is not mentioned in the non functional sources… Where would I find the relevant log for this?
What exactly does it say on the council website?
We’ve just had an issue here (not in your area) where the dates were correct on the website but they’d messed around with the text (they’d added something), and that scuppered the program.
I have a feeling that may be the case… The website only has this weeks display if you give it postcode and uprn. I sounds from the error its not getting something it expects in the returned string
