Watchdog found addon Zigbee2MQTT is failed, restarting
Hi
After updating to the newer version of home assistant core, i am seeing this error every 2 hours or so in my logs.
Is there any incompatibility? where could i see more info about the error?
Just taking a guess, but is the Zigbee2MQTT Addon actually running? If not, then it could be the supervisor is trying to restart it every couple of hours, and the reason it may not be running is that it is no longer able to communicate with the adapter.
you are totally spot on!
I have this in the logs
2025-12-06 19:29:30.812 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is failed, restarting…
The addon is running, all the zigbee devices are working but, every 2 hours, as you said, i have this error in the log!
Koenkk just released a new version of Zigbee2mqtt
So it was a known issue then, that explains it. Thanks!!
What was the final solution for this problem ? I have the same problem except it happens every few minutes…
I have version 2016.01.0 of the Supervisor and 2.7.2-1 of Zigbee2Mqtt
