For some reason suddenly watchdog keeps restarting my HASSIO exactly every ten minutes. I can’t remember that I have made any change to the system. And HASSIO just works fine (except the restarting…)
Now running .74. but also put a full snapshot back from .71 (which never had this). the Same issue. First I thought it was the power supply as this is a known ‘restart PI3’ issue but I’m almost sure it is is the watchdog that cannot reach the API (?). The watchdog log:
18-07-25 02:31:21 INFO (MainThread) [__main__] Initialize Hassio setup
18-07-25 02:31:21 INFO (MainThread) [__main__] Setup HassIO
18-07-25 02:31:21 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to supervisor homeassistant/armhf-hassio-supervisor with version 121
18-07-25 02:31:22 INFO (SyncWorker_0) [hassio.docker.interface] Cleanup docker images: ['homeassistant/armhf-hassio-supervisor:119']
18-07-25 02:31:23 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
18-07-25 02:31:23 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
18-07-25 02:31:23 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
18-07-25 02:31:24 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
18-07-25 02:31:24 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
18-07-25 02:31:24 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
18-07-25 02:31:24 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
18-07-25 02:31:24 INFO (MainThread) [hassio.host.info] Update local host information
18-07-25 02:31:24 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
18-07-25 02:31:24 INFO (MainThread) [hassio.host.services] Update service information
18-07-25 02:31:24 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
18-07-25 02:31:25 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
18-07-25 02:31:25 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on Host
18-07-25 02:31:25 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.74.0
18-07-25 02:31:25 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/a0d7b954 repository
18-07-25 02:31:25 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/core repository
18-07-25 02:31:26 INFO (MainThread) [hassio.addons] Load addons: 42 all - 42 new - 0 remove
18-07-25 02:31:26 INFO (SyncWorker_2) [hassio.docker.interface] Attach to image hassioaddons/ftp-armhf with version v1.3.0
18-07-25 02:31:26 INFO (SyncWorker_7) [hassio.docker.interface] Attach to image hassioaddons/appdaemon3-armhf with version v1.3.0
18-07-25 02:31:26 INFO (SyncWorker_6) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-samba with version 4.1
18-07-25 02:31:26 INFO (SyncWorker_3) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-ssh with version 3.7
18-07-25 02:31:26 INFO (SyncWorker_5) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-configurator with version 0.4
18-07-25 02:31:26 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-check_config with version 0.7
18-07-25 02:31:26 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
18-07-25 02:31:27 INFO (MainThread) [hassio.snapshots] Found 6 snapshot files
18-07-25 02:31:27 INFO (MainThread) [__main__] Run HassIO
18-07-25 02:31:27 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
18-07-25 02:31:27 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel
18-07-25 02:31:27 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
18-07-25 02:31:27 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons
18-07-25 02:31:27 INFO (MainThread) [hassio.core] Hass.io reboot detected
18-07-25 02:31:27 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
18-07-25 02:31:27 INFO (MainThread) [hassio.core] Hass.io is up and running
18-07-25 02:36:27 WARNING (MainThread) [hassio.homeassistant] Home-Assistant API config missmatch: 403
18-07-25 02:36:27 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-07-25 02:41:27 WARNING (MainThread) [hassio.homeassistant] Home-Assistant API config missmatch: 403
18-07-25 02:41:27 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-07-25 02:41:27 INFO (SyncWorker_7) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant docker application
18-07-25 02:41:39 INFO (SyncWorker_7) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-07-25 02:41:42 INFO (SyncWorker_17) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.74.0
18-07-25 02:43:12 INFO (MainThread) [hassio.homeassistant] Detect a running HomeAssistant instance
18-07-25 02:46:27 WARNING (MainThread) [hassio.homeassistant] Home-Assistant API config missmatch: 403
18-07-25 02:46:27 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-07-25 02:51:27 WARNING (MainThread) [hassio.homeassistant] Home-Assistant API config missmatch: 403
18-07-25 02:51:27 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-07-25 02:51:27 INFO (SyncWorker_8) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant docker application
18-07-25 02:51:35 INFO (SyncWorker_8) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-07-25 02:51:37 INFO (SyncWorker_9) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.74.0
After this it just keeps cycling every 10 mins:
18-07-25 02:53:08 INFO (MainThread) [hassio.homeassistant] Detect a running HomeAssistant instance
18-07-25 02:56:27 WARNING (MainThread) [hassio.homeassistant] Home-Assistant API config missmatch: 403
18-07-25 02:56:27 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-07-25 03:01:27 WARNING (MainThread) [hassio.homeassistant] Home-Assistant API config missmatch: 403
18-07-25 03:01:27 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-07-25 03:01:27 INFO (SyncWorker_8) [hassio.docker.interface] Stop homeassistant/raspberrypi3-homeassistant docker application
18-07-25 03:01:39 INFO (SyncWorker_8) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-07-25 03:01:41 INFO (SyncWorker_19) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.74.0
I’m running HASSIO behind a Caddy server (reversed proxy) but always did this. I have no entry under base_url in the configuration.yaml (never had). Hass is externally reachable via hass.yyy.com (no port needs to be added) and internally running under 192.168.192.196:8123
Any ideas? Driving me crazy and to make things worse I’m on the other side of the globe on holiday…
