Hey everyone, the issue was introduced in the new version 0.8.1, which is an almost complete rewrite of the Watchman.
I tested it in prod environment before the release and it seems the problem is not reproducible on all installations, but Iām working hard to fix it. I have removed 0.8.1 and 0.8.0 from the releases for the moment.
Version 0.7.0 beta.1 should work fine. Thank you for your understanding.
@scr I also asked on GitHub, but better safe than sorry:
Iām a little unsure. I installed V0.8.1 yesterday, and after a complete system restart tonight, triggered by Proxmox Backup of the HA VM, everything ran normally and without errors.
My question: should I downgrade? Could this problem still affect me?
confirmed, I went from release 6.x to new 8.x, borked the system.
I deleted altogether (so didnt do some nifty uninstall, I just deleted the folder and restarted (always first install add-ons Samba and SSH to be able to do that under any circumstanceā¦) and after that installed 7.0 beta 1.
Did have to reconfigure the options (it says migration failed somewhere, so ignore that and start all over with a fresh configuration)
And also be aware that community driven development means the author may not have the time to work on it straight away. In business, organizations pay for a Service Level Agreement with response times to fix problems. This is provided free of charge, as is.
Hey guys, development version 0.8.3 is ready! I would be incredibly grateful if those who previously experienced issues could test it in their environments. I have implemented extensive safety measures to minimize any risk of freezing.
However, as this is a test build, please proceed with reasonable caution: #227
I still only see 7 beta in HACS, no pre release of 8.x? A dev build is harder to test, seeing I also use markdown cards etc. and I wonāt be able to see if it can work with my previous config. Will it confict with an existing, disabled config?
Not yet. Iād like to get at least 5 confirmations first (I already have two). In the past, a pre-release was accidentally pushed to general users, so I donāt want to risk that again.
It actually isnāt. You donāt need to change anythingājust install it from the HACS custom repo and let it run to check the diagnostic sensors. Afterward, it can be safely removed without touching your existing 0.7 config.
Thatās a particular sore point for me, and I plan to address it in future releases. To support the markdown card, Watchman currently saves all report data in sensor attributes, which is architecturally incorrect. I might be able to implement a proper custom card to finally get rid of this approach.
P.S. I have to say, Home Assistant handles the load quite well. A sensor with 6,000 missing entities in its attributes (result of parser stress test) doesnāt impact performance at all, which is impressive.
I applied the update but did not reboot. I them did something that made the existing Watchman disappear from HA. But the reboot fix was still there. So, I selected cancel or such on it. It is still there. I am concerned about rebooting my HA. Is there anything I can do before a reboot to ensure that I am safe?
Already some days ago I removed the directory from custom_components, did a reboot and since then everything is fine. And now I wait until a well tested version is ready to download.
Iāve been dedicating almost all my free time over the last week, including most of the weekend, to fixing this issue. I have released 10 development versions so far, and while each brings improvements, the bug is tricky because it doesnāt reproduce in every environment (including my own three setups).
Therefore, I rely heavily on feedback from those of you generous enough to test the latest dev version (0.8.3-dev10). If the issue persists, please share your debug logs - it helps immensely.
All details regarding the dev versions can be found in the GitHub tickets #222 and #227. Thank you for your patience and understanding.
