Water Babies swimming lessons for Home Assistant
This integration synchronises your data from Water Babies adds calendar entries to Home Assistant which can be used in your own automations.
Enjoying this? Help me out with a
or
Installation through HACS
There is an active PR to get this into HACS, once that is merged then you can install the Water Babies integration by searching for it there in HA instance.
Until then you will have to add this repository manually:
Go to HACS -> 3 dot menu -> Custom Repositories:-
Paste https://github.com/jampez77/WaterBabies into Repository field and select Integration
Now you should be able to find it in HACS as normal.
You can install the Water Babies integration by searching for it there in HA instance.
Manual Installation
Use this route only if you do not want to use HACS and love the pain of manually installing regular updates.
- Add the
water_babiesfolder in yourcustom_componentsfolder
Data
This integration creates a sensor for your next milkround delivery date as well as information on number of milk bottles and wheelie bins saved. In addition you can add upcoming milkrounds to a calendar.
Contributing
Contirbutions are welcome from everyone! By contributing to this project, you help improve it and make it more useful for the community. Here's how you can get involved:
How to Contribute
- Report Bugs: If you encounter a bug, please open an issue with details about the problem and how to reproduce it.
- Suggest Features: Have an idea for a new feature? I'd love to hear about it! Please open an issue to discuss it.
- Submit Pull Requests: If you'd like to contribute code:
- Fork the repository and create your branch from
main. - Make your changes in the new branch.
- Open a pull request with a clear description of what you’ve done.
