i wanted to create an rieman sum, but it seems it shows wrong results?
after one toilet flush it shows 9.305 m3h. shouldn´t it be more like “0.09305” m3h? (9 liters)?
i want to use the utilitymeter and copied from my energy riemans… but i might be wrong. the watermeter_value is still the sum, so i will use it directly in my utility_meter?
You had to convert power sensors to energy sensor with a Riemann sum integral approximation because you had no energy sensors.
In this sistualtion it would be equivalent to you only having a flow rate (m3/h) that you wanted to convert to a total volume with the Riemann sum. However your sensor is not a flow rate. It is a volume total already. So yes just feed your water sensor to a utility meter directly with whatever cycle you want (hourly, daily, etc…).
but how i get rid of the old measurements from utilitymeter…?
with the wrong rieman i had switched unit_prefix, then i got sometimes (had taken 1h or so…) an repair to delete old values… but now? tried to comment out the utility_meter and rebooted, but it came back
