Salt sentry: Water softener monitoring device
For the last few months I’ve been busy creating a device to monitor when it is time to refill the salt blocks in my water softerner (Aquacell). I was tired of regularly checking whether I had to put new blocks of salt in it, and often forgot to do it on time.
I used a VL53L0X time of flight sensor to measure the distance from the top of the water softener to the salt blocks and a ESP8266 that connects to my wifi to send the measured distance and percentage to home assistant via MQTT:
I have a few left over and might get a bigger batch created if there’s interest: Salt Sentry - Water softener monitor from Lemcke Solutions on Tindie
That’s way cool! I’m using a door sensor now. Have to think this over a bit!
That is a little more custom than my setup.
I just have an ultrasonic sensor connected to a raspberry pi:
https://github.com/GlennGoddard/Salt-Level
That will probably work just as wel and might be a bit cheaper (If you can get hold of a raspberry pi).
I’ve struggled with corrosion in my softener and TOF sensor. Have you had one of these in place for a while?
I’ve had it in place for about 4 months now, no signs of corrosion at all.
That’s awesome, I’ll have to dig into mine more then.
Looks like I missed the boat on this. Any plans to create more? I’m using a Pentair salt monitor but it keeps resetting and has no integration with Home assistant.
I have ordered a new batch of 50 pieces, but due to component shortages, it is taking quite a bit longer than expected. It’s probably going to take another month before I have them.
They’re back in stock :slight_smile:
I was even able to shrink the height of it a bit by changing some components
I just came across these. I was wondering if this could be used to measure a water tank level?
@ErikNL Do you have some home assistant screenshots and/or the yaml to make this work?
Unfortunately, the sensor doesn’t work that well on water, if you can however put something floating in the water, it would work.
I configured the topic hal/saltsentry in the saltsentry I use myself, and added these two configurations to configuration.yaml
  - platform: mqtt
    name: "Salt sentry percentage"
    state_topic: "hal/saltsentry"
    qos: 0
    unit_of_measurement: "%"
  - platform: mqtt
    name: "Salt sentry cm"
    state_topic: "hal/saltsentry_distance"
    qos: 0
    unit_of_measurement: "cm"
In the UI, it looks like this:
@ErikNL Good deal, pretty straight to the point, thanks!
Mine arrived a few days ago. Set it up yesterday, it’s working like a charm! Nice work!
One small thing, at the bottom of page 7 of the English manual the second sensor setup should be state_topic: "hallway/saltsentry_distance"
Thanks for the comment, I’ve updated the manual.
I also recently (after a question from a user) tried to see if the module would wok with ESPHome, I got it working with the following code:
esphome:
esp8266:
  board: esp_wroom_02
i2c:
  sda: 2
  scl: 14
  scan: true
  - platform: vl53l0x
    name: "VL53L0x Distance"
    address: 0x29
    update_interval: 60s
    long_range: false
    unit_of_measurement: cm
The Salt sentry will now send the measured distance in cm to Home assistant. To get a full/empty percentage, you can configure a template senor.
Did some more fiddling around and came up with a better ESPHome config that will also calculate the percentage:
esphome:
esp8266:
  board: esp_wroom_02
i2c:
  sda: 2
  scl: 14
  scan: true
globals:
   - id: full_cm
     type: float
     initial_value: '5'
   - id: empty_cm
     type: float
     initial_value: '35'
  - platform: vl53l0x
    address: 0x29
    long_range: false
    internal: true
    icon: mdi:arrow-expand-down
    lambda: |-
      return id(distance_m).state * 100;
    unit_of_measurement: '%'
    icon: mdi:percent
    lambda: |-
      if (id(distance).state < id(full_cm)) {
        return 100;
      if (id(distance).state > id(empty_cm)) {
        return 0;
      return 100 - (id(distance).state - id(full_cm))  / ((id(empty_cm) - id(full_cm)) / 100);
The values in the “globals” section should be changed to reflect the number of cm when the water softener should be seen as full or empty.
Just ordered mine, bit of a price increase since i last checked, but that’s fine. Looking forward to this.
My Salt Sentry just arrived. Immediately I added it to ESPHome with your above code. I did a few things like:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "0142casdfasdcca51"
wifi:
  ssid: !secret wifi_ssid
  # Add a default domain name
  domain: .temp.nl
# Enable Web server.
web_server:
  port: 80
# Sync time with Home Assistant.
time:
  - platform: homeassistant
But for some reason the sensors present ‘unknown’.
If I check the logs I’m seeing the following:
[D][api.connection:917]: Home Assistant 2022.10.5 (192.168.21.92): Connected successfully
[D][time:041]: Synchronized time: 2022-10-26 16:28:14
[D][sensor:126]: 'distance': Sending state nan cm with 1 decimals of accuracy
[D][sensor:126]: 'percentage': Sending state -nan % with 1 decimals of accuracy
Any thoughts?
