Water Softner system SOLUCALC has electric pulse output on chip
I have a water softner at home (SOLUCALC)
This system has a computer chip with 4 exit pins on it. (as shown on the picture at the bottom of the chip)
My question now as it says “pulse OUT value” do you think I can just plug in some cables/pins and read this values out with an arduino/PI or will it be more difficult then that.
What integration would I need to read this.
I searched the net to find some technical documentation but i’m afraid they don’t share this on their website.
On monday I will call the company hoping they can share some technical info with me.
Kind regards
Jérémy
It’s looking promising and may well be simple.
I think it says valve not value.
I suspect the pulse is for water and valve is for gas?
As a first step I would check voltage across each pair with a multimeter?
It may well output a simple binary output signal you can use with a pulse counter (use ESPHome with an ESP32). Or perhaps it could be a more complex protocol like uart.
Edit:
Actually I think I’m mistaken. Looks like a pulse valve is a type of valve. So I guess it could be for controlling one too… Could be 4 pin uart.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://smstork.com/en/what-is-a-pulse-valve-how-does-the-pulse-valve-work%23:~:text%3DThe%20pulse%20valve%20gives%20the,hand%2C%20only%20use%20compressed%20air.&ved=2ahUKEwiKkbrQ_cf8AhVT8zgGHSpYCl0QFnoECBAQBQ&usg=AOvVaw0aglMKQ_i-l4DdhrNDLnfD
Hi Jérémy, I have the same unit and I wonder if you were able to make any progress to integrate the unit with HA. Thanks
