Hi All,
Currently Working with 6 Waveshare & 2 Elecrow ESP32-S3 Displays.
I'm Trying to create a Common Code Base across all devices.
Sensors & LVGL are no problem, as they are both 800x480 Displays.
Background Images being the Main Issue as the Elecrow only has 8 Meg of Flash, compared with the WaveShare's 16 Meg.
Display, Touch, I2C & IO Expanders are Different, but can be managed with Packages.
It's mainly the Core ESP32: Block of Code that I'm thinking of also making common,
noting that I will need to set the different Flash Size.
Essentially both brands are ESP32-S3's so wondering how much of that code can be reused in both.
Also is this the Most Current Set of Options for these ESP32-S3 Displays.
Here's what I have in each in that respect.
WaveShare's:-
esphome:
friendly_name: ${friendly_name}
platformio_options:
build_flags: "-DBOARD_HAS_PSRAM"
board_build.esp-idf.memory_type: qio_opi
board_build.flash_mode: dio
board_upload.maximum_ram_size: 524288
esp32:
board: esp32-s3-devkitc-1
variant: ESP32S3
flash_size: 16MB
cpu_frequency: 240MHz
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: y
CONFIG_ESP32S3_DATA_CACHE_64KB: y
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
psram: # Enable PSRAM on ESP32-S3
mode: octal
speed: 80MHz # Was 120MHz, but wouldn't Compile
And in the Elecrow's:-
esphome:
platformio_options:
esp32:
board: esp32-s3-devkitc1-n4r8
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESPTOOLPY_FLASHFREQ: "80MHz" # this is needed for flashing
CONFIG_ESPTOOLPY_FLASHMODE_QIO: y
CONFIG_FLASHMODE_QIO: y
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_240: y
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ: '240'
CONFIG_SPIRAM_RODATA: "y"
mode: octal
speed: 80MHz
Thanks.
