I got a working ESPHome config for the WaveShare ESP32-C6-GEEK, so I thought I’d share in case it’s useful for someone else. Getting the screen to work was the main pain point.
esphome:
friendly_name: ESP32 C6 GEEK
min_version: 2025.11.0
name_add_mac_suffix: false
on_boot:
priority: -100
then:
- light.turn_on: lcd_backlight
esp32:
variant: esp32c6
framework:
type: esp-idf
# Enable logging
logger:
level: DEBUG
globals:
- id: ha_status
type: std::string
restore_value: no
initial_value: '"Unknown"'
# Enable Home Assistant API
api:
on_client_connected:
- lambda: |-
id(ha_status) = "Connected";
on_client_disconnected:
- lambda: |-
id(ha_status) = "Disconnected";
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
# SPI Bus for the LCD
# Pin mapping (from Waveshare ESP-IDF demo & confirmed
# with CircuitPython on the actual hardware):
# SCLK = GPIO1 MOSI = GPIO2 DC = GPIO3
# RST = GPIO4 CS = GPIO5 BL = GPIO6
# BTN = GPIO9
spi:
clk_pin: GPIO1
mosi_pin: GPIO2
# Backlight via LEDC PWM (allows brightness control)
output:
- platform: ledc
pin: GPIO6
frequency: 2000
light:
- platform: monochromatic
output: backlight_pin
name: "Display Backlight"
icon: mdi:brightness-7
restore_mode: RESTORE_AND_ON
# Sensors for the display data
- platform: wifi_signal
update_interval: 10s
- platform: uptime
text_sensor:
- platform: wifi_info
ip_address:
ssid:
# The Onboard Button (GPIO 9, active-low).
# Pressing it cycles through the available pages.
binary_sensor:
- platform: gpio
pin:
number: GPIO9
inverted: true
mode: INPUT_PULLUP
on_press:
then:
- display.page.show_next: geek_display
- component.update: geek_display
# Color Palette (defined once, used across all pages)
color:
- id: clr_white
red: 100%
green: 100%
blue: 100%
- id: clr_grey
red: 50%
green: 50%
blue: 50%
- id: clr_red
red: 100%
- id: clr_green
green: 100%
- id: clr_blue
blue: 100%
- id: clr_yellow
red: 100%
green: 100%
- id: clr_orange
red: 100%
green: 64.7%
blue: 0%
- id: clr_bg_network
blue: 25%
- id: clr_bg_system
red: 25%
# Display Configuration
font:
- file: "gfonts://Roboto"
# ST7789 — 1.14" 135×240 (Waveshare ESP32-C6-GEEK)
# Using "Custom" model so we can set the exact offsets
# for this panel. The TTGO T-Display preset has its own
# pin defaults that don't match the GEEK.
# ST7789 controller is 240×320; our panel is 135×240.
# Portrait gaps: col 52|135|53 = 240, row 40|240|40 = 320
# After rotation 270°, offsets remap (Custom model does NOT
# auto-adjust). Values below are for the ROTATED frame:
# offset_width = 40 (240px width in 320-row space)
# offset_height = 52 (135px height in 240-col space)
display:
- platform: st7789v
model: Custom
width: 135
height: 240
offset_width: 40
offset_height: 52
cs_pin: GPIO5
dc_pin: GPIO3
reset_pin: GPIO4
backlight_pin: no # controlled separately via LEDC light
data_rate: 40MHz
update_interval: 500ms
rotation: 270
pages:
# ── PAGE 1: Network Status ──────────────────────
- id: page_network
lambda: |-
it.fill(id(clr_bg_network));
// 1px dashed border (4px dash, 4px gap)
int w = it.get_width(), h = it.get_height();
for (int x = 0; x < w; x += 8) {
int len = std::min(4, w - x);
it.horizontal_line(x, 0, len, id(clr_grey));
it.horizontal_line(x, h - 1, len, id(clr_grey));
for (int y = 0; y < h; y += 8) {
int len = std::min(4, h - y);
it.vertical_line(0, y, len, id(clr_grey));
it.vertical_line(w - 1, y, len, id(clr_grey));
it.print(120, 5, id(font_large), id(clr_blue), TextAlign::TOP_CENTER, "NETWORK");
if (id(wifi_ssid).state != "") {
it.printf(10, 40, id(font_small), id(clr_white), "SSID: %s", id(wifi_ssid).state.c_str());
it.printf(10, 60, id(font_small), id(clr_green), "IP: %s", id(wifi_ip).state.c_str());
it.printf(10, 80, id(font_small), id(clr_yellow), "RSSI: %.0f dBm", id(wifi_rssi).state);
} else {
it.print(120, 60, id(font_large), id(clr_red), TextAlign::CENTER, "Connecting...");
it.printf(230, 120, id(font_small), id(clr_grey), TextAlign::BOTTOM_RIGHT, "Pg 1/2");
# ── PAGE 2: System Monitor ──────────────────────
- id: page_monitor
lambda: |-
it.fill(id(clr_bg_system));
it.print(120, 5, id(font_large), id(clr_orange), TextAlign::TOP_CENTER, "SYSTEM");
it.printf(10, 40, id(font_small), id(clr_white), "Free Heap: %d B", esp_get_free_heap_size());
it.printf(10, 60, id(font_small), id(clr_white), "Uptime: %.0fs", id(uptime_s).state);
if (id(button).state) {
it.print(10, 80, id(font_small), id(clr_green), "Button: PRESSED");
} else {
it.print(10, 80, id(font_small), id(clr_grey), "Button: RELEASED");
it.printf(230, 120, id(font_small), id(clr_grey), TextAlign::BOTTOM_RIGHT, "Pg 2/2");
