pbleuland
(PBvO)
February 10, 2026, 10:46am
1
Hej! I am trying to find a good YAML example for the waveshare esp32-p4-wifi6-poe-eth board I bought. I get it to work on ethernet, but not on Wifi. Can someone support me in a correct YAML for Wifi? Thanks!
substitutions:
host_name: esp-p4-camera
device_comment: Test and play setup
device_name: esp_p4_camera
device_name_friendly: esp p4 camera
device_area: Garage
yaml_author: PBvO
yaml_version: 0.0.1
esphome:
name_add_mac_suffix: false
comment: ${device_comment}
friendly_name: ${device_name_friendly}
project:
version: ${yaml_version}
area: ${device_area}
platformio_options:
board_build.flash_mode: dio
esp32:
board: esp32-p4-evboard
flash_size: 16MB
framework:
type: esp-idf
wifi:
ssid: !secret wifi_ssid
fast_connect: true
post_connect_roaming: true
logger:
# hardware_uart: UART0
# level: DEBUG
api:
port: 6053
batch_delay: 30ms
encryption:
key: !secret api_key
ota:
- platform: esphome
password: !secret ota_password
web_server:
include_internal: true # Show entities marked internal on the web page
# HTTP request component for C6 firmware updates
http_request:
timeout: 10s
update:
- platform: esp32_hosted
name: "ESP32-C6 Firmware"
type: http
source: https://esphome.github.io/esp-hosted-firmware/manifest/esp32c6.json
update_interval: 6h
# ESP32-C6 WiFi interface via SDIO
esp32_hosted:
variant: ESP32C6
reset_pin: GPIO54
cmd_pin: GPIO19
clk_pin: GPIO18
d0_pin: GPIO14
d1_pin: GPIO15
d2_pin: GPIO16
d3_pin: GPIO17
active_high: true
#ethernet:
# type: IP101
# mdc_pin: GPIO31
# mdio_pin: GPIO52
# power_pin: GPIO51
# clk:
# mode: CLK_EXT_IN
# pin: GPIO50
# phy_addr: 1
# Optional manual IP
# manual_ip:
# static_ip: 192.168.3.187
# gateway: 192.168.3.1
# subnet: 255.255.255.0
text_sensor:
name: "ESP32-C6 Firmware Version"
lambda: |-
// This will show the C6 firmware version
return {"Check Update entity"};
update_interval: 60s
tmjpugh
(Tmjpugh)
February 10, 2026, 2:29pm
2
Are you getting an error when you try to flash or I does it not connect to
Look at below also
opened 04:42PM - 30 Sep 25 UTC
closed 01:42AM - 01 Oct 25 UTC
### The problem
I’m trying to use ESPHome on an **ESP32-P4** host with an **ESP… 32-C6 co-processor over SDIO** via the esp32_hosted integration to provide Wi-Fi. The node boots, the SDIO link appears to initialize, but **Wi-Fi association is unstable and usually fails**. Typical behavior:
Shortly after starting Wi-Fi, the log prints ESP-Hosted SDIO errors like:
- H_SDIO_DRV: Dropping packet(s) from stream
- H_SDIO_DRV: Failed to push data to rx queue
Then the connection attempt **times out**, followed by:
- Disconnected ... reason='Association Leave'
- wifi: Restarting adapter
This **loops repeatedly**. In some runs I also see:
- assert failed: netif_add ... (netif already added) during Wi-Fi re-init
- occasional Guru Meditation / Instruction access fault during early setup
If I comment out the wifi: block, the device runs stably (no reboots/panics), which points to the Wi-Fi path (hosted/SDIO) as the trigger.
What I expected: the P4 should associate/authenticate via the C6 and obtain an IP (DHCP or static) and remain connected.
What happens instead: repeated association failures/timeouts, SDIO RX drops, and occasional asserts/panics when the adapter restarts.
### Which version of ESPHome has the issue?
2025.9.1 & 2025.9.2
### What type of installation are you using?
Home Assistant Add-on
### What platform are you using?
ESP32
### Component causing the issue
esp32_hosted, wifi, esp32
### YAML Config
```yaml
# base YAML #
esphome:
friendly_name: P4 Hosted WiFi Test
esp32:
framework:
type: esp-idf
logger:
level: DEBUG
api:
ota:
- platform: esphome
# ESP32-C6 co-processor over SDIO
esp32_hosted:
variant: ESP32C6
reset_pin: GPIO54
active_high: false
clk_pin: GPIO18
cmd_pin: GPIO19
d0_pin: GPIO14
d1_pin: GPIO15
d2_pin: GPIO16
d3_pin: GPIO17
# slot: 1 - tried slot: 0 too
wifi:
power_save_mode: NONE
### Anything in the logs that might be useful for us?
```txt
[17:39:32]ESP-ROM:esp32p4-eco2-20240710
[17:39:32]Build:Jul 10 2024
[17:39:32]rst:0xc (SW_CPU_RESET),boot:0x30f (SPI_FAST_FLASH_BOOT)
[17:39:32]Core0 Saved PC:0x4ff03f56
[17:39:32]Core1 Saved PC:0x4ff01ba8
[17:39:32]SPI mode:DIO, clock div:1
[17:39:32]load:0x4ff33ce0,len:0x15f0
[17:39:32]load:0x4ff2abd0,len:0xd84
[17:39:32]load:0x4ff2cbd0,len:0x3310
[17:39:32]entry 0x4ff2abd0
[17:39:32]I (33) boot: ESP-IDF 5.4.2 2nd stage bootloader
[17:39:32]I (33) boot: compile time Sep 30 2025 17:37:29
[17:39:32]I (34) boot: Multicore bootloader
[17:39:32]I (35) boot: chip revision: v1.0
[17:39:32]I (36) boot: efuse block revision: v0.3
[17:39:32]I (40) boot.esp32p4: SPI Speed : 80MHz
[17:39:32]I (44) boot.esp32p4: SPI Mode : DIO
[17:39:32]I (47) boot.esp32p4: SPI Flash Size : 4MB
[17:39:32]I (51) boot: Enabling RNG early entropy source...
[17:39:32]I (56) boot: Partition Table:
[17:39:32]I (58) boot: ## Label Usage Type ST Offset Length
[17:39:32]I (65) boot: 0 otadata OTA data 01 00 00009000 00002000
[17:39:32]I (71) boot: 1 phy_init RF data 01 01 0000b000 00001000
[17:39:32]I (78) boot: 2 app0 OTA app 00 10 00010000 001c0000
[17:39:32]I (84) boot: 3 app1 OTA app 00 11 001d0000 001c0000
[17:39:32]I (91) boot: 4 nvs WiFi data 01 02 00390000 0006d000
[17:39:32]I (98) boot: End of partition table
[17:39:32]I (101) esp_image: segment 0: paddr=00010020 vaddr=40070020 size=26734h (157492) map
[17:39:32]I (130) esp_image: segment 1: paddr=0003675c vaddr=30100000 size=00044h ( 68) load
[17:39:32]I (132) esp_image: segment 2: paddr=000367a8 vaddr=4ff00000 size=09870h ( 39024) load
[17:39:32]I (141) esp_image: segment 3: paddr=00040020 vaddr=40000020 size=63d7ch (408956) map
[17:39:32]I (200) esp_image: segment 4: paddr=000a3da4 vaddr=4ff09870 size=05394h ( 21396) load
[17:39:32]I (205) esp_image: segment 5: paddr=000a9140 vaddr=4ff0ec80 size=02350h ( 9040) load
[17:39:32]I (210) boot: Loaded app from partition at offset 0x10000
[17:39:32]I (211) boot: Disabling RNG early entropy source...
[17:39:32]sdio_mempool_create free:190440 min-free:190440 lfb-def:147456 lfb-8bit:147456
[17:39:32]
[17:39:32][I][logger:165]: Log initialized
[17:39:32][C][safe_mode:084]: Unsuccessful boot attempts: 5
[17:39:32][D][esp32.preferences:143]: Writing 1 items: 0 cached, 1 written, 0 failed
[17:39:32][I][app:073]: Running through setup()
[17:39:32][C][component:163]: Setup preferences took 0ms
[17:39:34]Guru Meditation Error: Core 1 panic'ed (Instruction access fault). Exception was unhandled.
[17:39:34]
[17:39:34]Core 1 register dump:
[17:39:34]MEPC : 0x00000000 RA : 0x00000000 SP : 0x4ff190a0 GP : 0x4ff0f480
[17:39:34]TP : 0x4ff190c0 T0 : 0x4fc1a058 T1 : 0x20000000 T2 : 0xffffffff
[17:39:34]S0/FP : 0x00000000 S1 : 0x00000000 A0 : 0x00000000 A1 : 0x4ff2a408
[17:39:34]A2 : 0x00000004 A3 : 0x00000000 A4 : 0x20800008 A5 : 0x1f000000
[17:39:34]A6 : 0x00000000 A7 : 0x00000003 S2 : 0x00000000 S3 : 0x00000000
[17:39:34]S4 : 0x00000000 S5 : 0x00000000 S6 : 0x00000000 S7 : 0x00000000
[17:39:34]S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000
[17:39:34]T3 : 0x00000000 T4 : 0x00000000 T5 : 0x00000000 T6 : 0x4002360e
[17:39:34]MSTATUS : 0x00011880 MTVEC : 0x4ff00003 MCAUSE : 0x00000001 MTVAL : 0x00000000
[17:39:34]MHARTID : 0x00000001
[17:39:34]
[17:39:34]Stack memory:
[17:39:34]4ff190a0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff190c0: 0x00000000 0x4ff17ce4 0x4ff17ce4 0x00000000 0x00000000 0x00000000 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff190e0: 0xa5a5a5a5 0x00000160 0x4ff18d60 0x00000b0b 0x4ff1207c 0x4ff1207c 0x4ff190e8 0x4ff12074
[17:39:34]4ff19100: 0x00000002 0x4ff0f6ac 0x4ff0f6ac 0x4ff190e8 0x00000000 0x00000017 0x4ff17ce4 0x6f696473
[17:39:34]4ff19120: 0x6165725f 0x00000064 0x00000000 0x7fffffff 0x4ff190e0 0x00000017 0x00000000 0x4ff2a3f8
[17:39:34]4ff19140: 0x40049a3c 0x00000000 0x4ff141e0 0x4ff14248 0x4ff142b0 0x00000000 0x00000000 0x00000001
[17:39:34]4ff19160: 0x00000000 0x00000000 0x00000000 0x40045e26 0x00000000 0x00000000 0x00000000 0x00000000
[17:39:34]4ff19180: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[17:39:34]4ff191a0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[17:39:34]4ff191c0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[17:39:34]4ff191e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[17:39:34]4ff19200: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
[17:39:34]4ff19220: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x25f2b76f
[17:39:34]4ff19240: 0x24c091a5 0x4ff190e0 0x0000000c 0x4ff1a660 0x4ff13ba4 0x4ff19244 0x00001400 0xa5a5a5a5
[17:39:34]4ff19260: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff19280: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff192a0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff192c0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff192e0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff19300: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff19320: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff19340: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff19360: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff19380: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:34]4ff193a0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:35]4ff193c0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:35]4ff193e0: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:35]4ff19400: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:35]4ff19420: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:35]4ff19440: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:35]4ff19460: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:35]4ff19480: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
[17:39:35]
[17:39:35]
[17:39:35]
[17:39:35]ELF file SHA256: 385693e55
[17:39:35]
[17:39:35]Rebooting...
### Additional information
**Steps to reproduce**
1. Hardware: ESP32-P4 dev board with ESP32-C6 connected over SDIO (CLK/CMD/D0-D3) and a dedicated reset pin.
2. ESPHome config:
- esp32_hosted: with variant: ESP32C6
- SDIO pins set (CLK/CMD/D0-D3), slot: 1
- reset pin wired to the C6 reset (on my board: GPIO24) with active low (active_high: false)
- ESP-IDF framework (5.4.x), experimental features enabled
- sdkconfig_options: { CONFIG_ESP_WIFI_ENABLED: "n" } to disable the P4’s internal Wi-Fi driver
- wifi: with network credentials; tested both with and without bssid, with fast_connect: true, and power_save_mode: NONE
3. Flash and boot.
4. Observe logs: SDIO driver “dropping packet(s)” / “failed to push to rx queue”, then Connection timeout → Association Leave → Restarting adapter, repeating. Sometimes netif_add ... netif already added assert or a Guru Meditation.
I attach a minimal YAML and full boot/Wi-Fi logs showing these messages above.
**Additional information**
- Pins / polarity: Best results so far with reset_pin: GPIO24 and active_high: false (active-low reset). Using a wrong reset pin/polarity prevents the C6 from coming up at all. With the above, the SDIO stack initializes and produces Hosted driver logs.
- BSSID / fast connect: Tried with bssid locked to a known AP and fast_connect: true (to avoid a heavy scan). Also tried without BSSID (normal scan). Both paths still hit SDIO RX drops and end in timeout.
- Power save: power_save_mode: NONE at all times (to avoid sleep-related handshake issues). Still seeing the problem.
- Static IP: Tried DHCP and (in other tests) manual_ip:. The failure occurs before DHCP; association/auth appears to fail.
- Stability check: With wifi: commented out, the device runs and logs normally (no resets), suggesting the crash/loop is tied to Wi-Fi/Hosted init.
Other symptoms seen in some builds/runs:
- E ... esp_netif_lwip: dhcp client start failed
- esp_task_wdt_reset(...): TWDT was never initialized (warnings only)
- assert failed: netif_add ... (netif already added) during rapid adapter restarts
- occasional Guru Meditation (Instruction access fault) on Core 0/1 during setup
Environment details:
- ESP-IDF 5.4.x (platform 54.03.21)
- PSRAM enabled (200 MHz) and LDO configured; plenty of heap available
- Host: ESP32-P4; Co-proc: ESP32-C6 (ESP-Hosted firmware)
Hypothesis / request: The SDIO RX queue appears to overflow during association (handshake/scan), causing critical packet loss and a failed connect; subsequent rapid re-inits sometimes trigger netif_add asserts or panics. Guidance on:
- known fixes in ESPHome 2025.9.2+ or newer ESP-Hosted blobs,
- recommended SDIO buffer/queue tuning or SDIO clock adjustments for P4,
- exposing a YAML/IDF knob to increase Hosted RX queue / use PSRAM for Wi-Fi buffers, would be very helpful.
pbleuland
(PBvO)
February 20, 2026, 10:06am
3
Yes, simular problems, thanks for pointing to this topic!
