Hi, I try to use the ESP32-S3-ETH with a POE hat for the use of a soil moisture sensor.
First I tried to flash this with the ESPHome integration from HASS. That succeeded, and I had wireless connection.
I think I made an error with the configuration of the ethernet config. After I removed the wifi config and added the ethernet config, the device didn't react anymore to ESPhome.
Also the COM port disappeared after a while when I had the ESP connected. When I connected the ESP after a while, the com-port was active again. Flashing was still not possible by ESPhome, but only by esptool or web.esphome.io.
The last config I tried was the config below, which I saw on another topic on the HASS community.
Do I have a hardware failure? Or do I need to do other things with S3 devices than older ESP's?
What's the status with that configuration, exactly?
I cannot tell from experience for your device, but I generally would not use platformio_options and sdkconfig_options unless I know exactly why they are needed...
I tried the config, but it looks like it is in some kind of a boot-loop or something.
For a while I see a COM-port, but after a while it disappears. And the ESP won't react to anything.
Also if I have disconnected the ESP for a while, and I click it back in, the COM port appears again.
I swapped the cable, and the ESP kept his COM port for a longer time now.
But when it is visible, I can flash the ESP. I now did flash it with the new cable also.
But I don't get an IP-address. Wired or wireless.
Logging gives no output.
Also without baud_rate 0.
I also don't see the link led blinking (yellow) only the act(green) is blinking.
Network settings are correct and tested.
Using Python 3.14.2 environment at: C:\Users\taren\.platformio\penv\.espidf-5.5.4
INFO Build Info: config_hash=0xe2024b61 build_time_str=2026-05-25 19:10:55 +0200
INFO Successfully compiled program.
esptool v5.2.0
Connected to ESP32-S3 on COM6:
Chip type: ESP32-S3 (QFN56) (revision v0.2)
Features: Wi-Fi, BT 5 (LE), Dual Core + LP Core, 240MHz, Embedded PSRAM 8MB (AP_3v3)
Crystal frequency: 40MHz
USB mode: USB-Serial/JTAG
MAC: 3c:0f:02:d7:86:70
Stub flasher running.
Changing baud rate to 460800...
Changed.
Configuring flash size...
Auto-detected flash size: 16MB
Flash will be erased from 0x00010000 to 0x00077fff...
Wrote 425712 bytes (263341 compressed) at 0x00010000 in 2.7 seconds (1281.9 kbit/s).
Hash of data verified.
SHA digest in image updated.
Flash will be erased from 0x00000000 to 0x00005fff...
Wrote 20768 bytes (13278 compressed) at 0x00000000 in 0.2 seconds (692.3 kbit/s).
Flash will be erased from 0x00008000 to 0x00008fff...
Wrote 3072 bytes (132 compressed) at 0x00008000 in 0.0 seconds (870.1 kbit/s).
Flash will be erased from 0x00009000 to 0x0000afff...
Wrote 8192 bytes (31 compressed) at 0x00009000 in 0.0 seconds (2332.7 kbit/s).
Hard resetting via RTS pin...
INFO Successfully uploaded program.
INFO UART logging is disabled (baud_rate=0). Not starting UART logs.
