Waveshare ESP32-S3-LCD-3.16 sample config
I recently purchased a new WaveShare ESP32-S3-LCD-3.16 display and created a basic configuration. I couldn’t find any examples through searching, so I made one myself using Gemini. If you have any ideas for improvement, please feel free to add to this thread.
This example only covers the display-related parts; it’s not the complete code (the rest is standard).
esphome:
  platformio_options:
    build_flags: "-DBOARD_HAS_PSRAM"
    board_build.arduino.memory_type: qio_opi
psram:
  mode: octal
  speed: 80MHz
esp32:
  variant: esp32s3
  flash_size: 16MB
  cpu_frequency: 240MHz
  framework:
    type: esp-idf
    sdkconfig_options:
      #The following LVGL configuration option is for improving the frame rate (LVGL v8.3):
      CONFIG_LV_MEM_CUSTOM: y
      CONFIG_LV_MEMCPY_MEMSET_STD: y
      CONFIG_LV_ATTRIBUTE_FAST_MEM: y
    advanced:
      enable_idf_experimental_features: true
spi:
  clk_pin:  GPIO2 #SCK
  mosi_pin: GPIO1 #SDO
display:
  - platform: mipi_rgb #rpi_dpi_rgb
    model: custom
    update_interval: never
    auto_clear_enabled: false
    #color_order: RGB
    dimensions:
      width:  320
      height: 820
    de_pin:    40
    hsync_pin: 38
    vsync_pin: 39
    pclk_pin:  41
    cs_pin: 0
    #pclk_inverted: true
    pclk_frequency: 18MHz
    reset_pin: 16
    hsync_back_porch:  30
    hsync_front_porch: 30
    hsync_pulse_width:  6
    vsync_back_porch:  20
    vsync_front_porch: 20
    vsync_pulse_width: 40
    data_pins:
      red:
        - 17        #r0
        - 46        #r1
        - 3         #r2
        - 8         #r3
        - 18        #r4
      blue:
        - 21        #b0
        - 5         #b1
        - 45        #b2
        - 48        #b3
        - 47        #b4
      green:
        - 14        #g0
        - 13        #g1
        - 12        #g2
        - 11        #g3
        - 10        #g4
        - 9         #g5
    init_sequence:
      - [0xFF, 0x77, 0x01, 0x00, 0x00, 0x13]
      - [0xEF, 0x08]
      - [0xFF, 0x77, 0x01, 0x00, 0x00, 0x10]
      - [0xC0, 0xE5, 0x02]
      - [0xC1, 0x15, 0x0A]
      - [0xC2, 0x07, 0x02]
      - [0xCC, 0x10]
      - [0xB0, 0x00, 0x08, 0x51, 0x0D, 0xCE, 0x06, 0x00, 0x08, 0x08, 0x24, 0x05, 0xD0, 0x0F, 0x6F, 0x36, 0x1F]
      - [0xB1, 0x00, 0x10, 0x4F, 0x0C, 0x11, 0x05, 0x00, 0x07, 0x07, 0x18, 0x02, 0xD3, 0x11, 0x6E, 0x34, 0x1F]
      - [0xFF, 0x77, 0x01, 0x00, 0x00, 0x11]
      - [0xB0, 0x4D]
      - [0xB1, 0x37]
      - [0xB2, 0x87]
      - [0xB3, 0x80]
      - [0xB5, 0x4A]
      - [0xB7, 0x85]
      - [0xB8, 0x21]
      - [0xB9, 0x00, 0x13]
      - [0xC0, 0x09]
      - [0xC1, 0x78]
      - [0xC2, 0x78]
      - [0xD0, 0x88]
      - [0xE0, 0x80, 0x00, 0x02] # <-- Задержка 100 мс
      - delay 100ms
      - [0xE1, 0x0F, 0xA0, 0x00, 0x00, 0x10, 0xA0, 0x00, 0x00, 0x00, 0x60, 0x60]
      - [0xE2, 0x30, 0x30, 0x60, 0x60, 0x45, 0xA0, 0x00, 0x00, 0x46, 0xA0, 0x00, 0x00, 0x00]
      - [0xE3, 0x00, 0x00, 0x33, 0x33]
      - [0xE4, 0x44, 0x44]
      - [0xE5, 0x0F, 0x4A, 0xA0, 0xA0, 0x11, 0x4A, 0xA0, 0xA0, 0x13, 0x4A, 0xA0, 0xA0, 0x15, 0x4A, 0xA0, 0xA0]
      - [0xE6, 0x00, 0x00, 0x33, 0x33]
      - [0xE7, 0x44, 0x44]
      - [0xE8, 0x10, 0x4A, 0xA0, 0xA0, 0x12, 0x4A, 0xA0, 0xA0, 0x14, 0x4A, 0xA0, 0xA0, 0x16, 0x4A, 0xA0, 0xA0]
      - [0xEB, 0x02, 0x00, 0x4E, 0x4E, 0xEE, 0x44, 0x00]
      - [0xED, 0xFF, 0xFF, 0x04, 0x56, 0x72, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x27, 0x65, 0x40, 0xFF, 0xFF]
      - [0xEF, 0x08, 0x08, 0x08, 0x40, 0x3F, 0x64]
      - [0xE8, 0x00, 0x0E]
      - [0xFF, 0x77, 0x01, 0x00, 0x00, 0x00]
      - [0x11]
      - delay 120ms
      - [0xE8, 0x00, 0x0C] # <-- Задержка 10 мс
      - delay 10ms
      - [0xE8, 0x00, 0x00]
      - [0x3A, 0x55]
      - [0x36, 0x00]
      - [0x35, 0x00]
      - [0x29]
      - delay 20ms
lvgl:
  displays:
    - ips01
Device info: https://www.waveshare.com/wiki/ESP32-S3-LCD-3.16
Circuit diagram: https://files.waveshare.com/wiki/ESP32-S3-LCD-3.16/ESP32-S3-LCD-3.16-schematic.pdf
