Waveshare ESP32-S3 Tiny and the WS2812
The “tiny” is the one with the USB connector on an umbilical cable.
According to the pinout, the WS2812 is controlled via GPIO38.
However, this .yaml:
# Example configuration entry
light:
  - platform: fastled_clockless
    chipset: WS2812
    pin: GPIO38
    num_leds: 1
    rgb_order: RGB
    name: "FastLED WS2811 Light"
    effects:
      - strobe:
          colors:
            - state: True
              brightness: 50%
              red: 100%
              green: 0%
              blue: 0%
              duration: 200ms
            - state: False
              duration: 200ms
… gives a compilation error of:
Compiling .pioenvs/esp32-s3-tiny/lib64d/WiFi/WiFiMulti.cpp.o
In file included from .piolibdeps/esp32-s3-tiny/FastLED/FastLED.h:48,
                 from src/esphome/components/fastled_base/fastled_light.h:16,
                 from src/esphome.h:20,
                 from src/main.cpp:3:
.piolibdeps/esp32-s3-tiny/FastLED/fastpin.h: In instantiation of 'class FastPin<38>':
.piolibdeps/esp32-s3-tiny/FastLED/platforms/esp/32/clockless_rmt_esp32.h:178:23:   required from 'class ClocklessController<38, 60, 150, 90, (EOrder)10, 0, false, 5>'
.piolibdeps/esp32-s3-tiny/FastLED/chipsets.h:582:7:   required from 'class WS2812Controller800Khz<38, (EOrder)10>'
.piolibdeps/esp32-s3-tiny/FastLED/FastLED.h:103:52:   required from 'class WS2812<38, (EOrder)10>'
src/esphome/components/fastled_base/fastled_light.h:150:41:   required from 'CLEDController& esphome::fastled_base::FastLEDLightOutput::add_leds(int) [with CHIPSET = WS2812; unsigned char DATA_PIN = 38; EOrder RGB_ORDER = (EOrder)10]'
src/main.cpp:276:66:   required from here
.piolibdeps/esp32-s3-tiny/FastLED/fastpin.h:207:24: error: static assertion failed: Invalid pin specified
  static_assert(validpin(), "Invalid pin specified");
Any thoughts?
Regards, Martin
That looks like you don’t have all the libraries you need.
You need to provide a complete YAML (that is the minimal that shows the issue). I would also do a full clean first.
This issue looks relevant, use the workaround
Thank you Neel,
This is my complete .yaml (with the external component you suggested):
esphome:
esp32:
  board: esp32-s3-devkitc-1 #https://www.waveshare.com/esp32-s3-tiny.htm
  framework:
    type: arduino
external_components:
  - source: github://pr#4257
    components: [fastled]
    refresh: always
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
ota:
  - platform: esphome
    password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  domain: .peritonlane
  ap:
captive_portal:
web_server:
  port: 80
light:
  - platform: fastled
    chipset: WS2812
    data_pin: GPIO38
    num_leds: 1
    rgb_order: RGB
    effects:
      - strobe:
          colors:
            - state: True
              brightness: 50%
              red: 100%
              green: 0%
              blue: 0%
              duration: 200ms
            - state: False
              duration: 200ms
Now this compiles without errors. However, it does not work.
I know the WS2811 is working. If I jumper the Test Pad 38 to GPIO05 (nearest to GPIO38) and change the data_pin: to GPIO05, it works.
So I guess there is still a problem with pins.h (or whatever its called?).
Regards, M.
The issue showed the PR did not work in some cases and to use
neopixelbus
or
esp32_rmt_led_strip
instead.
