I have the 2.1" version of this display. viz : https://www.waveshare.com/wiki/ESP32-S3-Touch-LCD-2.1
Can’t seem to get text to display on the screen. It works with the Arduino demo though. I have found the touchscreen device is actually CST820 and seems to work fine and sends coordinates to debug UART ok.
Using the latest version of Esphome. lvgl version seems to be 8.4 from build logs.
log :
[12:50:53][C][pca9554:048]: PCA9554:
[12:50:53][C][pca9554:048]: I/O Pins: 8
[12:50:53][C][pca9554:052]: Address: 0x20
[12:50:53][C][logger:246]: Logger:
[12:50:53][C][logger:246]: Max Level: DEBUG
[12:50:53][C][logger:246]: Initial Level: DEBUG
[12:50:53][C][logger:252]: Log Baud Rate: 115200
[12:50:53][C][logger:252]: Hardware UART: USB_SERIAL_JTAG
[12:50:53][C][logger:259]: Task Log Buffer Size: 768
[12:50:53][C][i2c.idf:083]: I2C Bus:
[12:50:53][C][i2c.idf:084]: SDA Pin: GPIO15
[12:50:53][C][i2c.idf:084]: SCL Pin: GPIO7
[12:50:53][C][i2c.idf:084]: Frequency: 50000 Hz
[12:50:53][C][i2c.idf:094]: Recovery: bus successfully recovered
[12:50:53][I][i2c.idf:104]: Results from bus scan:
[12:50:53][I][i2c.idf:110]: Found device at address 0x20
[12:50:53][I][i2c.idf:110]: Found device at address 0x51
[12:50:53][I][i2c.idf:110]: Found device at address 0x6B
[12:50:53][C][spi:069]: SPI bus:
[12:50:53][C][spi:070]: CLK Pin: GPIO2
[12:50:53][C][spi:071]: SDI Pin:
[12:50:53][C][spi:072]: SDO Pin: GPIO1
[12:50:53][C][spi:077]: Using HW SPI: SPI3_HOST
[12:50:53][C][ledc.output:151]: Output:
[12:50:53][C][ledc.output:152]: Pin GPIO6
[12:50:53][C][ledc.output:153]: Channel: 0
[12:50:53][C][ledc.output:153]: PWM Frequency: 2000.0 Hz
[12:50:53][C][ledc.output:153]: Phase angle: 0.0°
[12:50:53][C][ledc.output:153]: Bit depth: 14
[12:50:53][C][light:092]: Light 'Display Backlight'
[12:50:53][C][light:094]: Default Transition Length: 1.0s
[12:50:53][C][light:094]: Gamma Correct: 1.00
[12:50:53][C][psram:016]: PSRAM:
[12:50:53][C][psram:019]: Available: YES
[12:50:53][C][psram:021]: Size: 8192 KB
[12:50:53][C][:179]: ST7701S RGB LCD
[12:50:53][C][display.st7701s:180]: Height: 480
[12:50:53][C][display.st7701s:180]: Width: 480
[12:50:53][C][display.st7701s:184]: CS Pin: 2 via PCA9554
[12:50:53][C][display.st7701s:186]: DE Pin: GPIO40
[12:50:53][C][display.st7701s:187]: Reset Pin: 0 via PCA9554
[12:50:53][C][display.st7701s:190]: Data pin 0: GPIO11
[12:50:53][C][display.st7701s:190]: Data pin 1: GPIO10
[12:50:53][C][display.st7701s:190]: Data pin 2: GPIO9
[12:50:53][C][display.st7701s:190]: Data pin 3: GPIO5
[12:50:53][C][display.st7701s:190]: Data pin 4: GPIO45
[12:50:53][C][display.st7701s:190]: Data pin 5: GPIO48
[12:50:53][C][display.st7701s:190]: Data pin 6: GPIO47
[12:50:53][C][display.st7701s:190]: Data pin 7: GPIO21
[12:50:53][C][display.st7701s:190]: Data pin 8: GPIO46
[12:50:53][C][display.st7701s:190]: Data pin 9: GPIO3
[12:50:53][C][display.st7701s:190]: Data pin 10: GPIO8
[12:50:53][C][display.st7701s:190]: Data pin 11: GPIO18
[12:50:53][C][display.st7701s:190]: Data pin 12: GPIO17
[12:50:53][C][display.st7701s:190]: Data pin 13: GPIO14
[12:50:53][C][display.st7701s:190]: Data pin 14: GPIO13
[12:50:53][C][display.st7701s:190]: Data pin 15: GPIO12
[12:50:53][C][display.st7701s:191]: SPI Data rate: 1MHz
[12:50:53][C][cst816.touchscreen:074]: CST816 Touchscreen:
[12:50:53][C][cst816.touchscreen:075]: Address: 0x15
[12:50:53][C][cst816.touchscreen:076]: Interrupt Pin: GPIO16
[12:50:53][C][cst816.touchscreen:077]: Reset Pin: 1 via PCA9554
[12:50:53][C][cst816.touchscreen:078]: X Raw Min: 0, X Raw Max: 480
[12:50:53][C][cst816.touchscreen:078]: Y Raw Min: 0, Y Raw Max: 480
[12:50:53][C][cst816.touchscreen:106]: Chip type: CST820
[12:50:53][C][lvgl:088]: LVGL:
[12:50:53][C][lvgl:088]: Display width/height: 480 x 480
[12:50:53][C][lvgl:088]: Buffer size: 100%
[12:50:53][C][lvgl:088]: Rotation: 0
[12:50:53][C][lvgl:088]: Draw rounding: 2
[12:50:53][C][web_server:310]: Web Server:
[12:50:53][C][web_server:310]: Address: esp32s3.local:80
[12:50:53][C][esphome.ota:073]: Over-The-Air updates:
[12:50:53][C][esphome.ota:073]: Address: esp32s3.local:3232
[12:50:53][C][esphome.ota:073]: Version: 2
[12:50:53][C][safe_mode:018]: Safe Mode:
[12:50:53][C][safe_mode:019]: Boot considered successful after 60 seconds
[12:50:53][C][safe_mode:019]: Invoke after 10 boot attempts
[12:50:53][C][safe_mode:019]: Remain for 300 seconds
[12:50:53][C][api:207]: API Server:
[12:50:53][C][api:207]: Address: esp32s3.local:6053
[12:50:53][C][api:217]: Using noise encryption: NO
[12:50:53][C][mdns:122]: mDNS:
[12:50:53][C][mdns:122]: Hostname: esp32s3
yaml :
# waveshare-esp32-s3-touch-lcd-2.8c
esphome:
esp32:
board: esp32-s3-devkitc-1
flash_size: 8MB
variant: esp32s3
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESPTOOLPY_FLASHFREQ: "80MHz" # this is needed for flashing
CONFIG_ESPTOOLPY_FLASHMODE_QIO: y
CONFIG_FLASHMODE_QIO: y
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_240: y
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ: '240'
CONFIG_SPIRAM_RODATA: "y"
# Enable PSRAM on ESP32-S3
psram:
mode: octal
speed: 80MHz
# Enable logging
logger:
api:
web_server:
port: 80
version: 3
ota:
platform: esphome
wifi:
ssid: XXXXXXXXXXXXXXXXXXXX
password: XXXXXXXXXX
# I2C bus configuration
i2c:
- id: i2c_bus
sda: GPIO15
scl: GPIO07
# PCA9554 GPIO extender for display reset
pca9554:
- id: p_c_a
address: 0x20
i2c_id: i2c_bus
# SPI bus configuration
spi:
- id: spi_lcd
clk_pin: GPIO02
mosi_pin: GPIO01
interface: spi3
# Backlight PWM output and light component
output:
# Backlight LED
- platform: ledc
pin: GPIO06
frequency: 2000Hz
channel: 0
light:
- platform: monochromatic
output: GPIO06
name: Display Backlight
restore_mode: ALWAYS_ON
gamma_correct: 1
# ST7701S Display configuration (adjust the init_sequence to match your display)
display:
- platform: st7701s
spi_id: spi_lcd
spi_mode: MODE1
color_order: bgr
auto_clear_enabled: false
#update_interval: never
show_test_card: true
dimensions:
width: 480
height: 480
cs_pin:
pca9554: p_c_a
number: 2
reset_pin:
pca9554: p_c_a
number: 0
de_pin: GPIO40
hsync_pin: GPIO38
vsync_pin: GPIO39
pclk_pin: GPIO41
init_sequence:
- [ 0xFF, 0x77, 0x01, 0x00, 0x00, 0x13 ]
- [ 0xEF, 0x08 ]
- [ 0xFF, 0x77, 0x01, 0x00, 0x00, 0x10 ]
- [ 0xC0, 0x3B, 0x00 ]
- [ 0xC1, 0x10, 0x0C ]
- [ 0xC2, 0x07, 0x0A ]
- [ 0xC7, 0x00 ]
- [ 0xCC, 0x10 ]
- [ 0xCD, 0x08 ]
- [ 0xB0, 0x05, 0x12, 0x98, 0x0E, 0x0F, 0x07, 0x07, 0x09, 0x09, 0x23, 0x05, 0x52, 0x0F, 0x67, 0x2C, 0x11 ]
- [ 0xB1, 0x0B, 0x11, 0x97, 0x0C, 0x12, 0x06, 0x06, 0x08, 0x08, 0x22, 0x03, 0x51, 0x11, 0x66, 0x2B, 0x0F ]
- [ 0xFF, 0x77, 0x01, 0x00, 0x00, 0x11 ]
- [ 0xB0, 0x5D ]
- [ 0xB1, 0x3E ]
- [ 0xB2, 0x81 ]
- [ 0xB3, 0x80 ]
- [ 0xB5, 0x4E ]
- [ 0xB7, 0x85 ]
- [ 0xB8, 0x20 ]
- [ 0xC1, 0x78 ]
- [ 0xC2, 0x78 ]
- [ 0xD0, 0x88 ]
- [ 0xE0, 0x00, 0x00, 0x02 ]
- [ 0xE1, 0x06, 0x30, 0x08, 0x30, 0x05, 0x30, 0x07, 0x30, 0x00, 0x33, 0x33 ]
- [ 0xE2, 0x11, 0x11, 0x33, 0x33, 0xF4, 0x00, 0x00, 0x00, 0xF4, 0x00, 0x00, 0x00 ]
- [ 0xE3, 0x00, 0x00, 0x11, 0x11 ]
- [ 0xE4, 0x44, 0x44 ]
- [ 0xE5, 0x0D, 0xF5, 0x30, 0xF0, 0x0F, 0xF7, 0x30, 0xF0, 0x09, 0xF1, 0x30, 0xF0, 0x0B, 0xF3, 0x30, 0xF0 ]
- [ 0xE6, 0x00, 0x00, 0x11, 0x11 ]
- [ 0xE7, 0x44, 0x44 ]
- [ 0xE8, 0x0C, 0xF4, 0x30, 0xF0, 0x0E, 0xF6, 0x30, 0xF0, 0x08, 0xF0, 0x30, 0xF0, 0x0A, 0xF2, 0x30, 0xF0 ]
- [ 0xE9, 0x36, 0x01 ]
- [ 0xEB, 0x00, 0x01, 0xE4, 0xE4, 0x44, 0x88, 0x40 ]
- [ 0xED, 0xFF, 0x10, 0xAF, 0x76, 0x54, 0x2B, 0xCF, 0xFF, 0xFF, 0xFC, 0xB2, 0x45, 0x67, 0xFA, 0x01, 0xFF ]
- [ 0xEF, 0x08, 0x08, 0x08, 0x45, 0x3F, 0x54 ]
- [ 0xFF, 0x77, 0x01, 0x00, 0x00, 0x00 ]
- delay 120ms
- [ 0x11 ]
- delay 120ms
- [ 0x3A, 0x66 ]
- [ 0x36, 0x00 ]
- [ 0x35, 0x00 ]
- [ 0x20 ]
- delay 120ms
- [ 0x29 ]
data_pins:
red:
- 46 #r1
- 3 #r2
- 8 #r3
- 18 #r4
- 17 #r5
green:
- 14 #g0
- 13 #g1
- 12 #g2
- 11 #g3
- 10 #g4
- 9 #g5
blue:
- 5 #b1
- 45 #b2
- 48 #b3
- 47 #b4
- 21 #b5
# CST820 Touchscreen Controller
touchscreen:
- platform: cst816
i2c_id: i2c_bus
reset_pin:
pca9554: p_c_a
number: 1
interrupt_pin: GPIO16
on_update:
- lvgl.label.update:
text: !lambda return str_sprintf("Touch points:\n id=%d x=%d, y=%d", touches[0].id, touches[0].x, touches[0].y);
- lambda: |-
for (auto touch: touches) {
if (touch.state <= 2) {
ESP_LOGI("Touch points:", "id=%d x=%d, y=%d", touch.id, touch.x, touch.y);
#LVGL Configuration
lvgl:
# - id: lvgl_display
displays:
- my_display
widgets:
- label:
align: CENTER
text_align: CENTER
text: 'Touch the screen'
Backlight works and is dimmable from the web UI but no text. IO table in the schematic seems to be the same as the 2.8 version.
