I got these batteries through a friend because he’s now powering his Victron system with even larger batteries. So I got two 5.12kWh storage units; I couldn’t say no.
[[Papool 48v 100Ah / identical to pylontech 100ah 48 V]](https://de.aliexpress.com/item/1005003764117272.html?spm=a2g0o.productlist.main.17.41ecw9lQw9lQ8F&algo_pvid=eec4e16b-1064-44f8-8ef6-9247ac4d26f7&algo_exp_id=eec4e16b-1064-44f8-8ef6-9247ac4d26f7-8&pdp_ext_f={"order"%3A"12"%2C"ev al%22%3A%221%22%7D&pdp_npi=4%40dis%21EUR%211520.96%21775.69%21%21%211612.21%21822.23%21%40210384b217427664122656570e5fd c%2112000046080827491%21sea%21DE%213411042977%21X&curPageLogUid=MReynQ0QDdMA&utparam-url=scene%3Asearch%7Cquery_from%3A)
With Waveshare RS485 to Wifi I get data from the Battery. That’s obviously working correctly. I’ve set the baud rate, etc.
I’m currently calculating the battery values based on what’s being charged and discharged. I factor in losses, and that works quite well. I read the battery voltage via the inverter and can use it to perform emergency shutdowns. So I have all the important data, but over time, the values will always shift slightly, and I won’t be running down to the basement every two weeks or so to correct them.
The BMS must have something to do with DR; in any case, it’s shown on the battery display and the program (USB serial) also references it.
So I tested all versions of BMS Pace last night, but unfortunately without success. New MQTT values were generated, just not filled in.
BMS Pace – Python Data Retrieval
So I kept searching and came across DR Switcher, with great hope. The title already lists the protocol that’s also listed in the USB program, “Protocol DR-1363.”
DR-JC03-RS485-Switcher
I fed the script from chatgpt with one of my HEX numbers today, but the resulting values don’t really match, except for the temperatures. So I’m not sure if it makes sense to install it on the Raspberry Pi now.
In any case, I learned that the HEX number is converted by the script and apparently a counter-request occurs beforehand, but I didn’t really understand that.
I found what I was looking for here in an English forum; others have the same problem.
I also need a solution for how to convert the HEX number using a script to the DR-1363 protocol. But unfortunately, I lack the knowledge to implement it on my own.
My last attempt yesterday was to create a local server to read the data with Scrape. Since I open the program in the browser, that would also be an option. Then a PC would always have to be connected, albeit via USB, to retrieve the data. That’s not so nice, and Scrape always requires an http address.
Oh, and then there are DIP switches 1-6. If dip 1 is on and the others are off, I can connect to the PC. If dip 6 is on and the others are off, I can retrieve the data via Waveshare.
Maybe thats helps to understand my Problem better.
