Way to Reorder Groups?
Is there any way to reorder the items in each view? I tried rearranging the groups in the yaml file but no dice. Any help is appreciated.
Configuration panel
Yep, you read that right. We have a configuration panel. It’s just the first of many small steps. Putting in a foundation is important and gives us something to iterate on.
To start, we have three simple configuration panels:
Core: allows you to validate config, reload core/group/automation config and restart/stop Home Assistant
Group: allows you to rename groups, change type between group/view and reorder entities.
Z-Wave: allows you to set device specific configuration settings
Fantastic. All i had to do was update. Thank you, i’ll mess with it a bit to see how it turns out!
Save a copy of your groups file BEFORE you try this!!!
Sort of worried to upgrade myself… heard some stuff.
But id definitely backup my config files when I eventually upgrade from 38.4
I would do a full image backup, then a quick copy of all your yaml if you’re considering .39.x.
Personally, I am waiting it out - for my first time since starting - for the next release.
I reorder groups by customize:
group.family:
  order: 4
group.weather:
  order: 5
group.lights:
  order: 6
group.heating:
  order: 7
group.media_player:
  order: 8
group.wire_devices:
  order: 9
What! why is that not in the documentation, didn’t know about that.
It sort of works. I do the same thing on one of my views. But it works in one view and not another.
I only found out about it from reading a post here myself.
For me it works for all views. Order numbers 4, 5, 6, 7, 8 is for first view, 9, 10 for next view.
